KingPin Bushing Reaming Service near Tulsa?... - Ford Truck Enthusiasts Forums
Oklahoma Chapter Join Chapter, Leader: Gary Lewis
Old 10-10-2013, 05:02 PM
cigarxtc's Avatar
cigarxtc cigarxtc is offline
cigarxtc has a great reputation on FTE.cigarxtc has a great reputation on FTE.cigarxtc has a great reputation on FTE.cigarxtc has a great reputation on FTE.cigarxtc has a great reputation on FTE.cigarxtc has a great reputation on FTE.
Anybody have any recommendations on where to take my spindles to get my new bushings reamed to fit my new kingpins?
I called 3 or 4 shops in Tulsa. One shop wanted to charge $300+ to put it in a chuck and actually machine it, i assume with a mill.
Another shop; Tulsa Auto Spring, said they can do it for $45 in about 2 hours.
The youtube vids show this simple process done in minutes if someone is using the proper machine that can ream both holes, inline, at the same time.
Old 10-11-2013, 11:15 AM
jwtimme jwtimme is offline
jwtimme is gaining momentum as a positive member of FTE.
I used Tulsa spring when I did mine, I'm assuming you went with the brass bushing instead of the nylon ones.
Old 10-11-2013, 06:19 PM
cigarxtc's Avatar
Ya, I went with brass bushing so I wouldn't have to do this again anytime soon. Were you pleased with Tulsa Spring cost/time? Do you know if they have the right equipment to do both top and bottom bushings at the same time to keep the axial line straight for the new kingpin?
Old 10-11-2013, 07:53 PM
If you don't keep them greased you will need to do it again, the nylon is suppose to not wear as bad under miss maintence. Also check the hole in the I beam for slop. I had to heat and beat mine closed and redrill and team out the I beam the last time I had mine apart. Tulsa spring does a lot of big truck stuff that use solid front axle so I would assume they had the correct tools. Mine came out good and fit like a glove. I did all this when converted to disk brakes.
Reaming F1 Kingpin Bushings hulleywoodworking 1948 - 1956 F1, F100 & Larger F-Series Trucks 6 10-29-2015 04:05 PM
f1 King pins tiger100 1948 - 1956 F1, F100 & Larger F-Series Trucks 17 07-30-2015 08:11 AM
F100 Kingpin replacement in Houston? rwrogers 1961 - 1963 F100 Unibody 1 05-28-2014 01:21 PM
Kingpin Replacement SonofaFord 1973 - 1979 F-100 & Larger F-Series Trucks 2 05-04-2014 07:24 AM
King Pin Bushings cujo8 Brakes, Steering, Suspension, Tires, & Wheels 7 08-18-2006 07:59 PM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
