7.3 error codes
This appears to be in the wrong location. Try posting at one of the forums below.
Super Duty
Super Duty & Heavy Duty - Ford Truck Enthusiasts Forums
Diesel - pick the 7.3 forum of the appropriate year
Diesel - Ford Truck Enthusiasts Forums
Super Duty
Also, be sure to mention what model year you are working on and if there are any symptoms, driveability issues, or other information that might help folks get the truck back on the road by Friday. The more information you can provide now, the fewer back and forth questions you'll need to address.
-Rod
-Rod
1249 Waste Gate Control Valve Performance
1209 Injection Control Pressure Peak delta test fault
0470 Exhaust Pressure Sensor
1211 Injection Control Pressure Higher/Lower than desired
More information about your truck would be helpfull. Does it have a chip?
Have you cleaned the exhaust pressure sensor and tube?
