solid axle dana 50 in obs f250
I have always been in the market for a 92-97 f250/f350. I currently have a couple 67-72 highboys...love them, my absolute favorite truck. I also have a 78 im puting a cummins in...But I have always wanted a 90s ford and when it comes to the ones in my area it seems you can get a nice f250 for cheap, and everyone that has an f350 keeps it or wants way to much for it...I dont have a huge problem with the ttb, I just like a solid axle better. I have considered a dana 50 swap idea as I can get 99-04 dana 50s for like $250 at a local salvage yard. But I dont want to run super duty lug pattern or unit bearings...is it possible to take outer knuckle, hubs, spindle and stub shaft from a dana 50 ttb and put it together with the inner knuckle and inner shaft of a dana 50 solid axle? Thought just keeps crossing my mind...but I dont know if the u joins are the same, or the ball joints are the same.
Thanks
Thanks
seems like a lot of work to just run a d50. might consider the other easy options...
I don't know what your local junkyards are like, but 8 lug 44's are pretty abundant around here. yea, its not a 50, but if youre not running tires larger than 33's there wouldn't be much to worry about.
also, im able to pick a 60 from time to time. might just want to keep an eye out for the big guy and save all other hassle.
Its probably more hassle then it would be worth...but I am kind of into doing things a little different...even though an 8 lug 44 would do just the same as a dana 50...it would have those tiny little 44 hubs sticking out, bleh...lol. I am just more curious about doing it then anything. Id probably be plenty happy with a ttb for what id use it for.
It won't work. The D50 TTB knuckle is a unique POS. You can swap a 92-97 D60 ball joint knuckle with a 99-04 D50 or D60 knuckle but you will also need the stub shaft. You could redrill the hub but I am not sure where you would find a 8x6.5 rotor to fit it and you would be stuck with the unit bearings unless you drop some cash on a conversion kit.
The solid D50 uses 30 spline inner shafts and the gears are slightly larger than a D44. The stub shaft and knuckle are the same as the D60.
BRay09
08-05-2012 07:40 AM
Troeder
09-08-2003 09:38 AM
the law
05-24-2002 10:38 PM
