Wheel adapters 5x4.5 to 5x5.5 - Ford Truck Enthusiasts Forums
Old 10-10-2013, 09:57 AM
51PanelMan's Avatar
51PanelMan 51PanelMan is offline
51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all
I'm contemplating on installing this into the 51 (pending confirmation that the CPP power booster and m/c kit will fit - see my other post: http://www.ford-trucks.com/forums/12...-in-an-f1.html)
However, it has a 5x4.5 bolt pattern. It appears to be a Speedway kit. I did some research and obtained two rotors with the 5x5.5 bolt pattern that come with the Speedway kit. I installed the new rotors yesterday, but the rotors are thicker than the 5x4.5 rotors. I called Speedway today and confirmed that the calipers, caliper brackets and spacers are different between the 5x4.5 and 5x5.5 kits.
With that in mind, I searched and found 5x4.5 to 5x5.5 wheel spacers.
http://www.ebay.com/itm/2pc-5-x-4-5-114-3mm-5-x-4-75-120-65mm-To-5-x-5-5-139-7-Wheel-Adapters-/261280684109?pt=Motors_Car_Truck_Parts_Accessories&hash=item3cd58ad84d&vxp=mtr
http://www.ebay.com/itm/2pc-1-25-Wheel-Adapters-5x4-5-to-5x5-5-Spacers-M12x1-5-Studs-5x114-3-to-5x139-7-/281184972685?pt=Motors_Car_Truck_Parts_Accessories&hash=item4177ee2f8d&vxp=mtr
The spacer is 1.25" thick. I'm wondering if this will push the wheel out to close to the fender. I'm running 15" wheels with 215/75 size tires. Measuring the approximate clearance now, there's about a 2.5" clearance between the top curve of the tire and the top of the fender (measuring horizontally - i.e., outwards).
Has anyone used wheel spacers/adapters with the stock configuration and had tire rubbing issues? What wheels/tires are you using?
Old 10-10-2013, 10:24 AM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is online now
postin' fool
ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.
The darkside is a slippery slope, isn't it?!
Old 10-10-2013, 10:30 AM
51PanelMan's Avatar
Quote:
I found a few cookie crumbles.
Old 10-10-2013, 01:15 PM
Dobies4life's Avatar
Dobies4life Dobies4life is offline
Dobies4life is starting off with a positive reputation.
Most likely it will. What you can do is order rims with different back spacing to offset. Which means you might as well just have 2 different bolt patterns, different back spacing limits tire rotation all the same. If its the bolt pattern for strength you want, a spacer reduces overall strength.
Its not per say the horizontal thats the issue its the vertical. Striaght axles arc upward where as arm suspensions arc up an inward. I realize that is a very general statement, but SLA suspensions have a little more forgiveness versus straight axle when it comes to tire clearance.
Old 10-10-2013, 10:51 PM
TireDood's Avatar
TireDood TireDood is offline
TireDood has a good reputation on FTE.TireDood has a good reputation on FTE.
Here's a pic of mine with the Speedway kit with the 5x4.5 rotors installed. Tire size is 215/70R15. Keep in mind that is has been lowered quite a bit... I think those spacers will put the wheels too far out.
Wheel adapters arkredneck 1978 - 1996 Big Bronco 3 11-06-2015 05:55 PM
HMMWV 24 bolt Wheel Install Ford F-350 Man 1987 - 1996 F150 & Larger F-Series Trucks 38 09-02-2015 03:24 PM
Before I buy these wheel spacers... Apocalypse Excursion - King of SUVs 118 07-18-2013 12:49 AM
come on guys i know you guys can answer this in 2 seconds cws10190 1973 - 1979 F-100 & Larger F-Series Trucks 18 09-25-2012 08:55 PM
5x5.5 to 5x4.5 Wheel Adapters CooGAR 1961 - 1966 F-100 & Larger F-Series Trucks 4 01-30-2012 08:31 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
