Brake power booster and master cylinder in an F1 - Ford Truck Enthusiasts Forums
Old 10-10-2013, 09:36 AM
51PanelMan's Avatar
51PanelMan 51PanelMan is offline
51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all
I'm trying to figure out if I have room to mount a CPP power booster and m/c kit in my 51 Panel. Before I puchase the kit, I'd like to see some pictures of this set up in a 48-52. The only issue that I may have is the fuel tank being in the way. On Panels, the fuel tank is mounted on the inside of the left rail directly after the stock m/c.
I'm also trying to see if I can use the stock pedal set up with the CPP kit.
This is the kit: http://www.ebay.com/itm/48-52-FORD-F100-TRUCK-POWER-BRAKE-BOOSTER-KIT-DISC-DRUM-/380691407755?pt=Vintage_Car_Truck_Parts_Accessories&hash=item58a2f9e38b&vxp=mtr
There's also this bracket: http://www.ebay.com/itm/1947-52-Ford-Truck-Power-Brake-Booster-to-Stock-Pedal-Adapter-Bracket-F1-pickup-/271229924419?pt=Motors_Car_Truck_Parts_Accessories&hash=item3f26903443&vxp=mtr
I'm not sure how this bracket works. Maybe this is a better solution since I'm space challenged???
Any pictures of the installed set up are greatly appreciated.
Old 10-10-2013, 12:19 PM
Doc's Avatar
Doc Doc is offline
Doc has much to be proud ofDoc has much to be proud ofDoc has much to be proud ofDoc has much to be proud ofDoc has much to be proud ofDoc has much to be proud ofDoc has much to be proud ofDoc has much to be proud of
Ilya, I have that exact same one on my 50 F-1 project. It is a very strong and quality piece. And, yes, it is designed to work with the stock pedal setup. I like it because it has that side brace which should keep it from flexing when the pedal is depressed. It sticks pretty far back from the crossmember. I'm guessing about 15-18 inches.
Old 10-10-2013, 10:57 PM
TireDood's Avatar
TireDood TireDood is offline
TireDood has a good reputation on FTE.TireDood has a good reputation on FTE.
Here 's a pic of mine installed. I built the mounting bracket instead of buying one... I am considering moving the proportioning valve, just don't know where I would move it to.
Old 10-15-2013, 05:43 PM
oscajo oscajo is offline
oscajo is starting off with a positive reputation.
brake booster mount.
Quote:
Might try this myself.
Thanks,
Oscar
1951 F3 Master Cylinder replacement sam03 1948 - 1956 F1, F100 & Larger F-Series Trucks 7 02-06-2015 03:38 PM
Darn willowbilly3 1947 and Older Ford Trucks 10 12-27-2014 11:30 AM
Master Cylinder option puddle 1948 - 1956 F1, F100 & Larger F-Series Trucks 4 11-19-2014 07:03 PM
1948-52 brake booster info Rimrock F1 1948 - 1956 F1, F100 & Larger F-Series Trucks 14 07-01-2014 01:59 PM
Wheel adapters 5x4.5 to 5x5.5 51PanelMan 1948 - 1956 F1, F100 & Larger F-Series Trucks 4 10-10-2013 10:51 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
