Is my thermostat stuck open? - Ford Truck Enthusiasts Forums
Old 10-10-2013, 07:18 AM
BATCruiser BATCruiser is offline
BATCruiser is starting off with a positive reputation.
I have a 2006 F350 6.0 and use the Torque OBD app on my Android tablet for my gauges. I haven't had a diesel truck before, so please excuse my ignorance . It was 45 degrees this morning and I went out for a drive in some foothills of NC. After 25 minutes of run time, (the last 15 at 55-60 mph) the highest the engine coolant temp got to was 183 degrees and went as low as 172 when going downhill. The engine oil temp ran between 183 and 191. As I understand it, the thermostat is not supposed to open until coolant temp hits 190. Is my thermostat stuck open?
Thanks for your help!
Old 10-10-2013, 07:45 AM
npccpartsman's Avatar
npccpartsman npccpartsman is offline
npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.
It's time to replace your thermostat.
Old 10-10-2013, 09:03 AM
egregg57's Avatar
egregg57 egregg57 is offline
egregg57 has a good reputation on FTE.egregg57 has a good reputation on FTE.egregg57 has a good reputation on FTE.
I have had the same thing happen three times! Do not buy an aftermarket Thermostat! Go with the Motorcraft part. I learned my lesson the hard way! The thermostat is not hard to change. You will need to drain some coolant to get it down below the thermostat itself. Do a search on Thermostat Replace and you'll find some tips.
But in short, yup your thermostat needs to be replaced.
Eric
Old 10-10-2013, 09:31 AM
clevelandtundra clevelandtundra is offline
clevelandtundra is gaining momentum as a positive member of FTE.
Yep, its stuck open. I had the same thing happen to mine too when I first bought the truck.
I just changed mine when I flushed the coolant and switched over to ELC. It is very easy, at least on the 2006 IIRC if you follow the thick upper radiator hose all the way down you'll see it connected right into it.
Part cost about $11 at the local Ford dealer.
Old 10-10-2013, 11:54 AM
99ExpyProblems 99ExpyProblems is offline
99ExpyProblems has a very good reputation on FTE.99ExpyProblems has a very good reputation on FTE.99ExpyProblems has a very good reputation on FTE.99ExpyProblems has a very good reputation on FTE.
Quote:
You just replaced the thermostat or the entire housing? Mine was $20 at Advanced Auto! I'll be getting a Motorcraft next time. Mine was replaced about 1.5 months ago and my truck is already dropping to 188 deg. When I first bought it, it was running 193, then 190, now 188. WTF?
Old 10-10-2013, 11:56 AM
Quote:
The entire housing.
Self inflicted stupidity tbruz 1973 - 1979 F-100 & Larger F-Series Trucks 45 12-29-2016 10:52 PM
Thermostat Conundrum Connecticut Calvin 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 08-11-2016 05:30 PM
Sudden overheating problem maxine 6.0L Power Stroke Diesel 20 07-21-2015 01:27 AM
Coolant Temp and Oil Temp Delta Towzilla 6.0L Power Stroke Diesel 16 05-26-2014 08:25 AM
Odd Thermostat Temp for Coolant Subzero68 6.0L Power Stroke Diesel 5 01-26-2014 12:56 PM
Tags
thermostat
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
