code P0301 - Ford Truck Enthusiasts Forums
code P0301
Old 10-09-2013, 09:21 PM
jfp3205 jfp3205 is offline
jfp3205 is starting off with a positive reputation.
code P0301
TRUCK HAS BEEN BUCKING A LITTLE BIT AROUND 45 MPH UNDER THROTTLE AND TODAY I HAD TO JUMP ON THE GAS TO PASS A TRUCK AND TRUCK BUCKED REAL BAD AND ENGINE LIGHT STARTED FLASHING
IT WENT OFF AND WHEN I WAS ABLE TO PUT THE SCANNER ON IT I WAS TOLD IT WAS A MISFIRE ON CYLINDER 1 AND CODE P0301
IS THIS JUST A PLUG OR IS IT A COIL ISSUE OR BOTH?
THANKS
Old 10-10-2013, 08:36 AM
jr105 jr105 is offline
jr105 is gaining momentum as a positive member of FTE.
Try switching the coil with another cylinder and see if the problem follows the coil.
Plugs been changed? Mileage?
2006 F-150 5.4 P0053 Stevenmed 2004 - 2008 F150 4 03-11-2016 11:28 AM
Misfire Cylinder 1 7.5l P0301 JonEB 1987 - 1996 F150 & Larger F-Series Trucks 7 10-30-2014 11:39 AM
96 3.0 boneyard06 Ranger & B-Series 7 04-19-2014 11:25 AM
got dtc p1299, p0301, p0308 got any advice? caseyoerding 1999 to 2016 Super Duty 8 03-30-2012 11:45 AM
1997 Expedition...flashing CEL and code p0301 mikeismadness 1997-2006 Expedition & Navigator 4 12-11-2011 02:48 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
