05 F250 suspension question
front of the 08 is same as 05-07 truck, but the rear of the 08 suspension is different from 99-07 trucks. the rear leafs are longer and have a different front leaf perch.
There is a company that sells the conversion hangers so you can install the 08 leafs into a 99-07 truck. but it's somewhat expensive for no real gain in my eyes
My 03 was a 6.0 that was stolen on fathers day morning. I had to get a new truck. I think the 350's had a stiffer but better ride then the 250's. I was wondering if the suspension from an 08 f350 will fit my 06 F250 for the stiffness. Plus I do tree work so having the heavier pay load is a plus. (It only comes with rear leaf helper springs.)
you have a slight confusion going on here
There is no difference between a F-250 and a F-350 in terms of weight carrying capacity. Their difference is on paper. Each truck has the same capacity. Each truck can get overload springs. It's all a paper game because in some states you have to liscnce F-350 as commercial, so guys buy F-250.
If you want your new truck to ride softer, try letting a little air out of the tires. What PSI are you running?
As far as rides go, the 08+ trucks ride softer and while they may be rated higher, they are known for sagging more than a 99-07 truck with the same weight load. This is due to the longer leaf springs and fewer leafs. Same strength, just more flex.
LargeFarva97
05-12-2018 01:37 AM
