Which aftermarket IFS kit for a 63?
I've decided against the Crown Vic IFS because I'm leary about the width being a bit wide and needing offset wheels.
I think I'd like a Mustang 2 kit (or other kits?) but there are so many different kits. Which one for a 63? Whole kits? Partial kits? If you buy just the crossmember how do you know what to get to finish it up? I was thinking I might get just the M2 crossmember then gather some new and some wrecker parts to save some money but how do I know what I need? Which springs, etc.?
Also I'd like a roughly 5" drop from stock height. How do you install the M2 to get the amount of drop desired?
Give Steve a Call at Industrial Chassis. He can hook you up with one of his custom fit Dakota kits.
In using the Dakota spindles and D150 mounts and calipers and rotor you maintain the 5 on 5.5 bolt pattern. It is also the same width as stock.
Here is one installed in a 63 and ride height
And the cross member
Industrial Chassis Inc. — Hot Rods and Customs Fabrication and Repair
Garbz
Garbz
slaney30
01-26-2013 01:27 AM
Oxfordrider
11-12-2012 06:07 PM
crazyredneckanyhow
04-07-2007 11:55 PM
