american racing outlaw II wheels rubbing brake caliper
is anyone else running these 15x10 wheels on their truck. I bought them new to replace the steel rims I had and they both have 4" backspacing and they slightly rub the brake caliper. short of putting a spacer on which I don't want to do I can't think of anything else to make them work,,,cuz you can't return them.
Is the truck in question a 3/4 ton? If so you will need to do a bit of grinding, but be careful not to get the calipers too hot. It's surprisingly easy to get the calipers hot enough to compromise the seals.
