New 1975 F250 Highboy - Ford Truck Enthusiasts Forums
Old 10-09-2013, 01:14 PM
38-55wcf 38-55wcf is offline
38-55wcf is starting off with a positive reputation.
Picked up a 75 Highboy that's rotted to hell. Got a 360 with a S-code 4bbl intake and holly 600. Dipstick pinch between exhaust manifold and head. Really really rotted. No floor or rocker on driver side and seized transfer-case linkage and column shift linkage haha. Planning on turning it into a wheeler. So far I'm trying to get it running and fabbing a floor shifter for it.
[IMG][/IMG]
[IMG][IMG]http://i1151.photobucket.com/albums/o626/38-55wcf/Mobile%20Uploads/IMG_7129
_zpsd3ff2b48.jpg[/IMG]
[/IMG]
[IMG][/IMG]
Old 10-09-2013, 01:27 PM
turbohunter's Avatar
turbohunter turbohunter is offline
turbohunter has a brilliant futureturbohunter has a brilliant futureturbohunter has a brilliant futureturbohunter has a brilliant futureturbohunter has a brilliant futureturbohunter has a brilliant futureturbohunter has a brilliant futureturbohunter has a brilliant futureturbohunter has a brilliant futureturbohunter has a brilliant futureturbohunter has a brilliant future
Holy crap have you got some work ahead of you!
We will be here to keep you into it.
Old 10-09-2013, 01:35 PM
FordFanboy's Avatar
FordFanboy FordFanboy is offline
FordFanboy is starting off with a positive reputation.
Wow. I sometimes think that people are too quick to swap cabs, but in this case, it might be time.
Old 10-09-2013, 01:46 PM
montana_highboy montana_highboy is offline
montana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud of
If anything that's a testament to how well these trucks were built, the fact the cab is still "intact" says a lot.
I assume your d/s cab mount is solid? something has to be holding the cab up.
Old 10-09-2013, 04:50 PM
Yea it's just where you see it gone is only spot rotted. it's a shame that the rest cab is pretty much mint. and u like most trucks the front frame is rotted so the motor never leaked much so that's a good thing.
Old 10-09-2013, 05:53 PM
On mine the leaking oil and winter road cinders encapsulated the metal, preserving it very well.
Old 10-09-2013, 07:00 PM
77&79F250's Avatar
77&79F250 77&79F250 is online now
Used OEM parts guy
77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future
Great place to throw a beer can while out driving the fire breaks, oops never mind that would be $ you would be throwing away, throw it in the SD bed instead.....?
Better put some nerf bars on it, so the cab has something to fall on to. lol
Old 10-09-2013, 10:18 PM
Yeah she's a piece. Got it running tonight with a new "75" green grommet module and she fired right up. Timing still isn't really right but overall at least it runs and carb doesn't seem to leak. Time for shackle flip and drop brackets. I got some 37 surplus tires to put on it.
Old 10-09-2013, 10:22 PM
77&79F250's Avatar
Used OEM parts guy
Have fun grinding rivets....you re-using the factory stuff or getting aftermarket Rough Stuff or Sky Manufacturing flip kit?
Old 10-09-2013, 10:27 PM
This is what happens when distributor is in 180* backwards. Haha loud bang and this...
[IMG][/IMG]
Old 10-09-2013, 10:28 PM
As far as the hangers go. I'm just gonna make my own or use chevy hangers and hopefully use 64" Chevy rears if I can get some cheap. All my springs now are rotted junk.
Old 10-09-2013, 11:19 PM
77&79F250's Avatar
Used OEM parts guy
Yea you east coast/CT boys have it rough in the salt zone.
That's a new full flow thru design muffler.
Old 10-10-2013, 11:01 PM
Tonight I got a b&m megashifter welded to a slanted raised box I welded up. Got the shifter for free and didn't have a consul/cover and for it so I didn't really mind welding to it. Anyhow it needs a new cable and that should let me shift my tranny, the column linkage is rusted solid
[IMG][/IMG]
Old 10-10-2013, 11:07 PM
this is kina where I wanna mount it. anyone have any suggestions, I'm gonna make a longer rod for it and extend that lockout rod to if need be
[IMG][/IMG]
Old 10-10-2013, 11:18 PM
77&79F250's Avatar
Used OEM parts guy
Since you are going a cable shift route, I would move it back closer to the front edge of the seat, less leaning fwd to shift.
What is this? mountain dewd 1961 - 1966 F-100 & Larger F-Series Trucks 4 05-06-2016 02:32 PM
Working son if a gun v2.0 Jrob69f100 1967 - 1972 F-100 & Larger F-Series Trucks 2 04-08-2016 12:30 AM
2V Triton V10 parts, heads, crank, pistons, rods, etc. 1997 katoranger Ford Truck Parts for Sale 1 03-02-2015 12:23 PM
Run in with Construction Barrier Austin J. 1997 - 2003 F150 4 12-13-2014 10:37 AM
Opps. 77mud Offroad & 4x4 15 09-13-2014 10:08 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
