Changing Gear ratios - Ford Truck Enthusiasts Forums
Old 10-09-2013, 11:47 AM
FordYoungGun35's Avatar
FordYoungGun35 FordYoungGun35 is offline
FordYoungGun35 is gaining momentum as a positive member of FTE.
truck is in my sig. Right now it has 3:55 and with my 5.0 and 33" tires it certainly doesn't have crazy off the line power. Don't get me wrong it isn't a dog because of some minor upgrades but I want better off the line power. Is changing the ratios something I could easily do myself?
Old 10-09-2013, 03:56 PM
Hankster1958 Hankster1958 is offline
Hankster1958 is starting off with a positive reputation.
EASIEST way??? Find a good axle from a donor truck with the ratio you want, it's a unbolt/bolt in operation. Now, one of the other guys here, will have to explain how to set up the speed sensor etc if it has one.
Setting up the Ring and Pinion in YOUR axle, requires some special know how, I'ds not do it myself.
Old 10-09-2013, 04:37 PM
what are the chances of finding a 4x4 with 4:10 and isn't shot
Old 10-09-2013, 04:41 PM
do the years matter? and could I use a f250 axle?
Old 10-09-2013, 04:44 PM
rla2005's Avatar
rla2005 rla2005 is online now
rla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud of
Quote:
In my neck of the woods.....slim to none.
Old 10-09-2013, 04:51 PM
exactly lol
Evan_P's Avatar
Evan_P Evan_P is offline
Evan_P is a splendid one to beholdEvan_P is a splendid one to beholdEvan_P is a splendid one to beholdEvan_P is a splendid one to beholdEvan_P is a splendid one to beholdEvan_P is a splendid one to beholdEvan_P is a splendid one to behold
I found a front diff with 4.10's, but the PO put them in. I think I'm going to have to redo it as well. But, for $100 for the diff and an entire rear axle I can't complain. Keep an eye out. They are out there, you just have to look.
Old 10-09-2013, 05:11 PM
rla2005's Avatar
It is not rocket science to install gears but it does require some special tools and knowledge. Trying to explain it over the web is futile at best. It is not for the average do-it-yourselfer. You could try to find axles from a F250 but then you would have to use 8-lug wheels.
Personally I do not think a swap from 3.55 to 4.10 (that is the shortest gear you will likely find in a donor) is going to do much for you. That 5.0L needs gears to get moving. The larger the tire, the shorter the gear you need. I have recommended 4.56s to you and others with similar combos before. When it comes to gears go big or go home.
Old 10-09-2013, 05:40 PM
lisagoud lisagoud is offline
lisagoud is starting off with a positive reputation.
pm sent thank you
Old 10-09-2013, 06:14 PM
Hey, I never promised you a Rose Garden! LOL!
Installing a R & P requires setting up proper lash etc, if you get it either too much, or too little, you'll eat them up fast. Find someone who knows his stuff, and let him set the pinion depth. But WATCH him, so you can do it next time!
Old 10-09-2013, 08:52 PM
garthneddy's Avatar
garthneddy garthneddy is offline
garthneddy is gaining momentum as a positive member of FTE.
Finding a third member for the front axle with 4.10s will be cake. Many F250s left the factory with 4.10 gears and the third members are 100% bolt in, even if it's a D50.
That leaves just one axle to regular if you can find an 8.8 from a 1/2 ton with 4.10s
Old 10-09-2013, 09:26 PM
Diesel_Brad's Avatar
Diesel_Brad Diesel_Brad is offline
Diesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud of
Quote:
Originally Posted by garthneddy View Post
....Many F250s left the factory with 4.10 gears and the third members are 100% bolt in, even if it's a D50......
I REALLY dont see that being the case, since a D44 uses a different ring rear than a D50
Old 10-09-2013, 09:53 PM
garthneddy's Avatar
Quote:
I wasn't saying that a D50 gear set would bolt into a D44 third member. I was saying a D50 third member will bolt into the D44 axle beams, replacing the entire factory third member.
Old 10-10-2013, 06:20 AM
Axle shaft are the same diameter and spline count? What about the u-joint?
Old 10-10-2013, 08:33 AM
garthneddy's Avatar
Axle shafts are in fact the same diameter and spline count. Actually, a very popular upgrade for the off-road crowd using the stock 1/2 ton TTB is to swap in the D50 center stub shaft to get a larger u joint in that location.
Finally checked my gear ratio JPMallory 1948 - 1956 F1, F100 & Larger F-Series Trucks 12 09-23-2015 11:49 AM
Gear ratio? engage 3.8 & 4.2L V6 1 07-04-2015 08:00 PM
speedo gear ? please miottimouse 1973 - 1979 F-100 & Larger F-Series Trucks 3 05-24-2013 10:34 AM
C6 gear ratio change tex2046 Clutch, Transmission, Differential, Axle & Transfer Case 1 11-22-2006 02:02 PM
429 Ping and No Power catbird7 Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 4 08-29-2003 05:46 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
