Need advise on broken steel line
Welcome to FTE. You can do a few things 1) temporarily cut out the damaged section and replace it with rubber hose and clamps... 2) Replace the damaged section with tubing or replace the entire line when you have time. It is not a hard job to do. The lines are for transmission cooling . '92
Unthread the fitting from the radiator. GO to your local Auto-parts store, they will have what you need
Sorry Brad... Tried that and exhausted all the stores but one... I plan on hitting that one up Monday. They all say the dont have one that will fit. Looking for a place to order the fitting or a way to remove the twisted steel tube from the fitting... I am a bit fearful just to start cutting it.
If you are trying to buy a new fitting then why are you scared to cut the old one up.
The reason why it's hard to find a new nut is because ford used a deep fitting. Hardware store or parts store will have a brass fitting with the 1/4npt and 3/8 brake line flare. Then you get a 3/8 compression coupling and a piece of 3/8 brake line and hook it together.
Of you cut the flared part off the twisted line/fitting mess with a hack saw, then use a drill bit to either drill it through, or try tapping it out with a hammer. It's just going to take a little time and it will be reusable. Then a compression fitting and new brake line to finish the project.
rb8484
02-28-2016 08:29 PM
Nathan Cox
10-20-2015 11:42 AM
RailDawg
1997-2006 Expedition & Navigator
12-19-2009 12:02 PM
