Smart phone and Navbar...... Does anyone else use a android or iphone to check in here on a regular basis. Mine phone just automatically switched to the Navbar when I log in and it is crappy. I don't like it at all.
Android, and I'll view the forums, but posting is weird. Sometimes it just doesn't reply, or type right for some reason. So I'll just view the forums best I can when I am working, or when I know I'll not be at a computer for a couple months.
Driver side drop or passenger? high or low pinion? Standard or reverse rotation? 1/2 or 3/4 ton? oem axles or chromoly axles? leaf or coil spring or coil over or nitergen shock? Regular tie rod or ram asst steering? Front or Rear axle? 4 or 3 link?
Driver side drop-- high pinion- Reverse rotation- oem axles coil springs or Regular tie rod -- Front axle-- 2 link track bar-- Weld on C mounts not solid. I do not know if it is 1/2 or heavy half or 3/4 ton. :-) I don't know if it has disk or drum but I am betting drum.
Well gears pends on what size tire and what trans/t-case you are gonna use. Lockers pends on what 4x4 system and what ya use it for. Axles pends one them first things an how hard ya play.
What rear axle you using and what gear ratio is it? How much money do you to build it?
If money is there I would do chromly axles,selctable locker if driven on street, gears wold depend on what gears are in rearend and if need to change for bigger tires.
Anyone need Novalog 70/30 quick pens-- Doc's office sent in the wrong script- insurance company won't take them back or refund- so I am out $350-- I would like to help someone out, instead of tossing them.
I have a co worker who is interested. Let me know.
