1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
99 F 250 4wd Super duty Shimy down hill only?
Old 10-09-2013, 12:44 AM
LesWard's Avatar
LesWard
LesWard is offline
Ok , here is one for ya.
My F 250 has a pretty good shimmy at around 65 to 75 but ony when going down hill. It seems to intensify on the steeper grades.
I am thinking possibly not enough caster and when going down hill the geometry changes enough to start the shimmy. It will subside as soon as it levels out.
Up hill or level it drives fine and is smooth and steers well.
Any thoughts? It has the solid front 4wd axle .
Thanks Les
Old 10-09-2013, 06:04 AM
redford's Avatar
redford
redford is offline
Received 1,549 Likes on 904 Posts
Wow, that is a strange one.
Do you feel the shimmy in the seat, the steering wheel, the gas/brake pedals, or in the entire truck?
Does this shimmy change with speed, like change frequency when you speed up? Does the amplitude change with speed (like does it get stronger when you go faster)?
Old 10-09-2013, 09:07 AM
LesWard's Avatar
LesWard
LesWard is offline
I think mostly in the steering wheel, but also through out the whole truck, just not as bad.
It does increase in severity with speed.
How does one adjust caster with the solid front axle ?
I assume some sort of tapered shims.
Thanks, Les
Old 10-09-2013, 10:31 AM
scotttahoe's Avatar
scotttahoe
scotttahoe is offline
I just did wheel hub assembly, ball joints, tie rod ends, axle/drive shaft U-joints, entire brake job, and much more on my E99 250 and I don't think you can use shims on a solid axle w/leaf springs. Are you coasting down hill or riding your brakes a little?
Old 10-10-2013, 08:11 AM
LesWard's Avatar
LesWard
LesWard is offline
Yes I tried coasting while in neutral , also light braking, accelerrating ,
shimmy remains constant while going down grade, subsides as soon as road levels out.
Talked to alignment shop and he said they have spacers to provide caster adjustment. Going on Tuesday, will post results.
thanks to all
Les
ethand320
1997 - 2003 F150
02-27-2014 09:41 AM
skiduty
09-30-2008 08:02 AM
sturoe
02-14-2008 07:30 AM
tai-tanium
06-15-2004 04:37 PM
Quick Reply: 99 F 250 4wd Super duty Shimy down hill only?
