Transfer case shift knob removal - Ford Truck Enthusiasts Forums
Old 10-08-2013, 10:00 PM
MattyJessome MattyJessome is offline
MattyJessome is starting off with a positive reputation.
Transfer case shift **** removal
Ive been trying to figure out how to remove this **** today, and I know i've read a few posts of people trying and they say the **** cant be removed but I just dont believe it! I cut off some of the rubber on the **** with a knife and its all white plastic underneith.. I just dont believe that its actually impossable to remove the **** lol has anyone had any luck?
Old 10-09-2013, 08:18 AM
P.Bronner P.Bronner is offline
P.Bronner is gaining momentum as a positive member of FTE.
I THINK the rod is finely splined and the **** is pressed on. Are you wanting to install a custom ****/handle? If so you may need to remove the lever from the vehicle and carefully grind the end down to the appropriate diameter for threading to your desired size. If removal of the **** remains a problem, heat it and the lever with a dryer or heat gun (be careful with a heat gun) and it should soften and slide off fairly easily.
Old 10-09-2013, 11:38 AM
Yeah ill be replacing it with a Hurst T-Handle.
I just ordered one so once I get it ill work on getting the stock **** off, ill come back here and let you know how it went lol
Old 10-13-2013, 12:07 AM
papasmurf40's Avatar
papasmurf40 papasmurf40 is offline
papasmurf40 is starting off with a positive reputation.
Just make an adaptor to slip over the splines and a threaded end to match the shift ****. I did that on my old 1989 F150.
Dash Knob Removal 72CC428 1967 - 1972 F-100 & Larger F-Series Trucks 4 06-02-2016 04:25 PM
Wiper switch knob Ripemdry 1973 - 1979 F-100 & Larger F-Series Trucks 17 02-26-2016 11:42 AM
How do I remove the headlight switch knob??? atomicjoe23 1973 - 1979 F-100 & Larger F-Series Trucks 28 07-12-2015 07:52 PM
4x4 Shift Knob Removal? Cluney93 1999 to 2016 Super Duty 1 08-18-2014 12:58 AM
Shift Knob Removal 1984F2506.9 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 11 01-19-2014 05:06 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
