Custom Fenders?
Old 10-08-2013, 07:58 PM
Filthy1955F100's Avatar
Filthy1955F100
Filthy1955F100 is offline
Custom Fenders?
Okay, so I am in love with this truck. With mine, I am running 20s and won't be able to have the rear fender all the way on the ground. I will have the front on the ground and I want it to be level. On this truck if you look at the rear fenders they're mounted up a lot higher then stock. But yet it is still touching the ground. You can tell the fender has been extended down. I was wanting to do this but really wasn't sure how he did it? Can I get some help please?
Trevor
Old 10-09-2013, 12:18 AM
EffieTrucker's Avatar
EffieTrucker
EffieTrucker is offline
Phantom of the Phorum
I would guess the easiest way would be to take a healthy pair of fenders and use fender patch panels to extend them down.
They look wide, so they may be the 3" wider fiberglass fenders with fiberglass extensions. They appear to slope in at the bottom, eliminating the need for a running board pocket.
Just a couple of thoughts.
Old 10-09-2013, 09:13 AM
bjmayberry2's Avatar
bjmayberry2
bjmayberry2 is offline
It looks to me like the truck has been channeled. Did you see the inside of the bed? Look at where the cab is compared to the Frame. With that much body drop the fenders maybe stock length, width looks to be 3" wider.
Old 10-09-2013, 11:04 AM
Filthy1955F100
So could I channel the cab and bed, then raise the fenders up?
Old 10-09-2013, 11:13 AM
bjmayberry2
I believe so! But I'm not familiar with how channeling actually works. I would think to get everything lined up you'd have to do something with the front sheet metal too. Do a web search and see if that provides you more info.
Old 10-09-2013, 11:15 AM
bjmayberry2
Old 10-09-2013, 11:26 PM
EffieTrucker
I really don't think the truck is channeled.
Looking at how far the back of the rear fender is off the ground, with the front of the rear fender touching the ground, I think just the fender was raised, then extended back to the running board.
If it were an unmodified fender, the back would only be a few inches off the ground.
As low as the fenders and running boards hang below the frame, I don't really see an advantage to channeling an effie. You can put them on the ground with an IFS/4-link RS. It would be far easier to notch the frame than to channel the body.
Just my opinion, of course.
Edit: Your truck is coming along nicely, Filthy. Most rear fender patch panels are around 6". Your fenders look like they're rusted about 2-2.5" up. You might be able to get 3-4" of extension with the standard patch panel. If you wanted to go that route.
Old 10-10-2013, 11:36 PM
keith56_cruz_cab's Avatar
keith56_cruz_cab
keith56_cruz_cab is offline
just a little sheetmetal work
pic of mine in progress
Old 10-11-2013, 07:45 AM
EffieTrucker
Just a little.
It's looking awesome! Looks like you're almost ready for primer.
Is the tailgate operable? (hidden hinges)
Old 10-11-2013, 09:19 AM
vintage tin's Avatar
vintage tin
vintage tin is offline
Keith,that truck is sick.i think when that is finish it will send women and children running.
i love it.
Old 10-11-2013, 09:28 AM
GB SISSON's Avatar
GB SISSON
GB SISSON is offline
Very cool! Is thet a coin slot over the back window? We all need one to pour the $ in!
Old 10-11-2013, 09:36 AM
Drewski 2's Avatar
Drewski 2
Drewski 2 is offline
Keith has the truck finished and is on to other projects......as I recall.
Old 10-11-2013, 09:47 AM
lowtrkn2k's Avatar
lowtrkn2k
lowtrkn2k is offline
I was wondering the other day whatever happened to Keith's build. Nice to see it's all done, ya that is one bad a$$ truck.
Keith any videos or pics of it in action? Very nice job by the way!
Old 10-11-2013, 11:21 AM
Rimrock F1's Avatar
Rimrock F1
Rimrock F1 is offline
Very Cool !!! Definitely Darkside.
Steve Bennett
11-08-2016 01:26 PM
BOB FERGUSON
08-04-2013 10:16 PM
kc 300EX
12-04-2008 06:58 PM
51truck
09-21-2008 09:00 PM
Tottspop
1947 and Older Ford Trucks
01-21-2005 10:44 AM
Quick Reply: Custom Fenders?
