What am I doing wrong?
Well I've been driving my highboy around for a couple weeks now, and I have to say, I'm slightly dismayed by the mpg I've been getting.
I read all around that people with the 300/np435 combination were getting anywhere from 16-20 mpg based on driving habits and front/rear gearing, even in the highboys. So far, I've gotten 12.7, 13.4, and 11.5 mpg. Most of my driving is highway, with an average of 55 mph. Twice a week I go off island for college, where I see brief periods on the freeway around 70 mph. Now the most recent mpg might have been affected by a short (~5 miles) trip with a 600lb compressor loaded in the bed. I'm not expecting for this to get super high mpg, but I at least hoped it would be a little better..
As far as measuring, I fill up the cab tank (19 gal), mark the OD reading, and drive until I run out of gas and mark the OD reading again. Then I simply take the difference in the OD readings and divide by 19.
-Jameson
-Jameson
Don't try to calculate the mileage like that.
Fill it up, record the mileage. Drive it until you have a 1/4 tank or less. Fill it up again and record the gallons it took. Record the mileage.
Deduct the original mileage from the last mileage.
Take the mileage driven and divide by number of gallons used, that's your MPG.
Example:
You fill up and the mileage is 59,763.4 you drive it and fill up again, this time the mileage is 60,024.8 and you filled up with 21.6 gallons.
60,024.8
-59,763.4= 261.4
You drove 261.4 miles and used 21.6 gallons so that's 261.4 divided by 21.6=12.1 MPG.
Example:
60,024.8
-59,763.4= 261.4
Example:
60,024.8
-59,763.4= 261.4
Example:
60,024.8
-59,763.4= 261.4
I agree with mike - the problem is that you can't tell exactly how much fuel you put in unless you refill it to a known level - i.e. full.
But otherwise as far as mileage goes, a lot of it comes with tuning. Vacuum connections/hoses are the first offenders. Ignition timing and points gap/dwell (if applicable) can affect it too, as well as carb settings. Then plugs, wires, etc etc. Vacuum would be the first step for me.
The 300 is a heck of a lot better on fuel than the larger V8's. A "dirty running engine" is improperly tuned/maintained.
Just wondering if you use the ferry or the bridge when you leave the island? I was on Whidbey Island around labor day. Was looking for your highboy but didnt see it. Just use whatever gallons it takes to fill the tank to figure out your mpg. Personally Id be happy with your mileage in a highboy even with a 300. Thats a lot of truck to move and keep moving. Plus everyone lies about what they actually get in fuel mileage ha ha
I think what the others are hitting on is the fact of the gauge not being accurate . Empty being the least accurate . So pick a half or quarter mark . Fill from there . Record the gallons . Next half or quarter ( Half may give better results ) fill and account for miles and gallons . Record over at least 4 fill ups to get an accurate record of MPG .
Well then Ford let A LOT of improperly tuned engines off the assembly line. I was doing emission tests on BRAND NEW fuel injected 300 six cylinders back in the late '80's and I had a problem getting the sixes to pass emissions with less than 5,000 miles on them.
-Jameson
I'm referring to the older carb'd 300's, though what can you expect out of an early EFI, crude EFI system?
