2004 6.0 weird noise and power loss - Ford Truck Enthusiasts Forums
Old 10-08-2013, 07:41 PM
Kelceykzk Kelceykzk is offline
Kelceykzk is starting off with a positive reputation.
I have a 2004 f250 6.0 powerstroke. A few days ago the turbo started making a random fluttering noise or turbo fart sound. It would just do it at random times. So I pulled the egr valve and cleaned it cause it was gunned up a little. I put it back on the truck and it continued to do it. Then yesterday when I was driving it it made another weird noise. If you accelerate real hard and try to build up boost it sounds like an air hose is leaking or there is a big suction of air and loud exhaust leak and it feels like the truck has limited power like its in limp mode almost. There is no check engine lights or anything on? It only does it if you put the pedal to the floor otherwise it acelerates normal any other time. Any ideas?
Old 10-08-2013, 07:47 PM
JWC 3's Avatar
JWC 3 JWC 3 is offline
JWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputation
Sounds like a boost hose or clamp issue . I would ck those first . If an air rush or leak sound is heard , That is .
Old 10-09-2013, 12:46 AM
04badford 04badford is offline
04badford has a brilliant future04badford has a brilliant future04badford has a brilliant future04badford has a brilliant future04badford has a brilliant future04badford has a brilliant future04badford has a brilliant future04badford has a brilliant future04badford has a brilliant future04badford has a brilliant future04badford has a brilliant future
X2 the CAC boots will crack and split,also the CAC Intercooler is of plastic check real closely for cracks, next will be the Map connection to Intake check the hose and nipple to intake that little hole will be clogged.
Random sound like a small animal being run through the fan after start up. twigsV10 1999 to 2016 Super Duty 7 09-24-2015 03:42 PM
2004 ford f450 6.0l 2wd drive 30kmiles lack of power F-WhiteThunder 1999 to 2016 Super Duty 0 05-04-2015 01:43 PM
Powermax turbo high pitched noise RedDevil460 6.0L Power Stroke Diesel 5 03-11-2015 03:13 PM
Strange 6.0 L noise maxine 6.0L Power Stroke Diesel 33 10-12-2014 09:50 AM
Air noise from front of Engine? dogdoc1 6.0L Power Stroke Diesel 20 01-08-2014 11:20 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
