1990 F150 both brake dash lights on
I have a '90 F150 and both the yellow ABS light and the red BRAKE light are on.
It was fine until my buddy did a little brake work for me, including replacing a couple brake lines and a parking brake cable. He bled the system at the lines going into the front calipers because the bleeder valves on the calipers where corroded and frozen. I then replaced the calipers and bled the system properly. Three times. I don't think the problem is from the brake work.
The brakes still work, by the way. The pedal just feels a bit spongy and I think the brakes don't work as well as they could.
If the truck is not running, I can pump the brakes a few times, and it will make a sound like it's sucking air a few times. Then the sound stops and the pedal firms up.
If the truck IS running, it keeps making the sucking air sound no matter how many times I pump it, and the pedal feel stays the same.
I think it might be a bad brake booster. Just wanted to see if any one else has a different opinion before I go out and spend my money.
the abs module should be under your left foot on the drivers side on the frame it is bolted on the frame and has brake lines coming out of it ill look to see if I can get a pic. good luck
if you get a sucking noise it would be the booster the front of the booster comes thru the front of the cab and it sounds like you have a bad seal and when you don't have the petal pushed in it holds the vacuum in and doesn't make a noise what I would do is press in the petal and see if you can feel any thing around the front of the booster in side of the cab if you feel it sucking in it is bad. also check and make Shure that you have the right calipers on the right side.
Well, I felt around the area on the firewall by the brake booster while I pushed on the pedal, but I couldn't feel any air moving around. It just makes the sucking sound. But I also went and started up my Mazda car, and it makes the same kind of sound, just not as loud, probably because it's a compact car. The vacuum hose from the manifold to the brake booster under the hood also looks good. The pedal doesn't exactly feel all that responsive, but then again, it is a truck. It's probably the same as every, and I just never paid that much attention. The brakes definitely work fine. So I guess I'm going to have to start replacing ABS sensors and see if that does the trick.
Well they could be unrelated. My friend put on a new e-brake cable and didn't bother to adjust it. I've just been putting it in gear to keep it from rolling, which brings me to the next point. The truck is a manual, so I can't put it in park, seeing as how manuals don't have park. How inconvenient.
Matt Wilson
11-20-2006 12:37 PM
schleeb
06-20-2001 08:25 PM
