87 problem
The first thing I would look at is fuel pressure. If your 87 is EFI (I don't know if Ford went EFI in 87 or if it was 88), test the pressure on the fuel rail, if it is low (I wish I knew the psi to look for. Engine size might matter), then look at the filter, and then the pumps starting with the high pressure pump on the frame rail, moving to the in tank low pressure pump(s).
Sorry I'm not much help. I'm sure you will get much more detailed answers from the experts on here. I'm still learning about my 88 f250 I've only had for a couple weeks.
on
tempest411
10-20-2013 01:54 AM
darrengj
11-28-2005 10:18 PM
BigSix1
12-18-2003 04:14 PM
