Frame Swap
Frame Swap
So my truck is an F150 2wd with a great rust free body and the truck has some sentimental meaning to me. I had an idea about swapping the body onto a 4x4 f250 frame, I would rather have it become a heavier duty 4x4 truck and this seems like a fairly easy way to do it. The body would be a direct bolt on correct? Would I be able to bolt the body on to any frame from 1980 to 1997? Just an idea I've thought of, thanks for your input
Yes, as long as it's the same wheelbase, it will bolt up. But, you may have gas tank problems. Since you have a 86 body, you need to stick with the older sending units since the guages are different around 88 and later, so those later tanks won't work with your older fuel gauge. Your truck is also fuel injected most likely, so if you put a carbed engine/frame under your body, you may need completely new tanks or sending units, since your sending units/tanks have fuel pumps inside them.
Your 86 front bumper may or may not bolt up to a 87 and later frame. I was recently told it would, but double check to make sure.
And of course your GVWR on your door tag won't be correct for a f250. Not a problem unless something legal happens and they find you where grossly overloaded according to your GVWR tag.
I haven't had firsthand experience with this, but I'm looking into a cab swap so I've done a little research. From what I can tell, you'll need to keep in mind that you'll have to make a hole for the transfer case shift lever if your current truck is automatic and the new truck is a 4x4. The cover on a stock 4x4 is pretty big, but you could probably get away with cutting a much smaller hole and the shift boot will cover it. Best of luck.
Also your location says Mechanicsburg. Are you in PA?
It can be done, you will just have to come up with a plan.
Yes. But I will warn you, the sending units in all these trucks are famous for wearing out, and the diesel units are hard to find and very expensive if you do. They are different because the have a return line fitting, but no electric pump in the tank.
trash
13
09-01-2012 01:12 AM
s10 warrior
07-30-2012 06:02 PM
FTE Ken
07-25-2002 02:08 AM
