Fenderwell bushings - Ford Truck Enthusiasts Forums
Fenderwell bushings
Old 10-07-2013, 11:28 PM
Danleig's Avatar
Danleig Danleig is offline
Danleig is starting off with a positive reputation.
Fenderwell bushings
OK guys I tried a little due diligence in the forum to see if this has been discussed, but it either hasn't or my search terms were bad.
When I tore down my '57, the inner fenderwells have a bushing at the bottom where the fenderwell mounts to the cab, one on each. Mine are really dried out and hard, and I don't see where anyone is re-popping them. Has anyone substituted a different part or had any other creative solution?
Old 10-08-2013, 03:26 PM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
Originally Posted by Danleig View Post
When I tore down my '57, the inner fenderwells (fender aprons) have a bushing at the bottom where the fenderwell mounts to the cab (cowl aka dash panel), one on each side.
Soak 'em in hot water, this will make them more pliable, easier to re-install. Re-using the originals is what you're faced with, unless you make your own.
FoMoCo referred to these bushings as "straps" aka "anti-squeaks" were installed where two or more pieces of sheet metal could rub together.
Look at 16A054 in pic, is this what you're asking for? If so: Strap - Front Fender Apron to Dash Panel - Improvise from tire carcass (!).
Old 10-08-2013, 05:08 PM
MARC's Avatar
MARC MARC is offline
MARC is starting off with a positive reputation.
I made mine out of pieces of mudflaps
Old 10-08-2013, 07:45 PM
spurredon's Avatar
spurredon spurredon is offline
spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.
I made mine from wide black belting that I found at a farm supply store.
Old 10-08-2013, 11:47 PM
Danleig's Avatar
Quote:
Well there is a rubber-ish welting that runs vertically along the back of the fenderwell where it meets up against the cab, and that's probably for the squeeking.
But for my money, 16A054 in the drawing looks more like the bracket that mounts to the cab that holds the bushing to which I am referring. Here are my parts laid out:
And here is a closeup of the bushing in the fenderwell:
Its kind of a rubber doughnut with a metal sleeve through the middle. The bolt that holds it to the cab bracket has a large "toothed" washer that when tightened, seems to expand the doughnut and anchor the back of the fenderwell.
Ya know what I mean?
Old 10-09-2013, 06:32 PM
spurredon's Avatar
That's a new one for me but what do I know. Thanks for the pics, saves tons of confusion. You could still make your own out of thick tough rubber.
Painting the rear fenderwells? StreamlineGT 2017 Super Duty 8 01-14-2017 04:41 PM
Fenderwell Exit Headers Exhaust Size COFLHTK 1973 - 1979 F-100 & Larger F-Series Trucks 4 02-08-2016 10:49 PM
ABS wire routing queen of spades 1999 to 2016 Super Duty 4 03-23-2015 06:52 AM
460 fenderwell headers fordman300 Offroad & 4x4 5 09-20-2005 09:26 PM
Can't find the Fuel Pump Relay 1992 f-150 cbutcher 1987 - 1996 F150 & Larger F-Series Trucks 14 06-27-2005 10:03 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
