Won't start
Won't start
1994 Ford 460 EFI. The first time you start it the truck runs fine. Let it run for a couple of minutes and shut it off and try to start it again and all it does is crank smells like it is flooding itself. If I leave the truck sit for about a hour I can go back out and it will start. I have placed a code reader and received error codes for the temp sensor, throttle position sensor, intake air temperature. I have replaced the temp sensor and tps sensor still having the same problem. I had this problem a couple of weeks ago and found that the wire was broken that went from the battery to the body ground was broken. This temporary fixed the problem for about a week, now i'm back to the same thing and I'm lost. My father and I spend about two hours a night trying to figure this out. Please help me.
This is Dad. My son sent me this post this AM. Subford, You are talking about the sensor attached to the intake right under the Throttle plates (under the cobra neck) right? It does have 2 wires. Just a quick question With the truck running if I plug the hose that runs into that sensor with my thumb it idles down or if I remove the wires going to it it idles down but acts like it is loading up. I read your post about changing the air temp sensor. No we have not but I will give that a try. Another thing this all started after we switched the cab. The old one was a rust pile. We gutted each of the cabs and reinstalled all the old wiring dash etc from the old cab in to the new along with the computor etc. All grounds are good. I will get a intake air temp sensor ordered and give that a try. Thanks
just reread earlier posts and looking at the picture. We had replaces the ECT Sensor not temp sender as stated in the first post and the TPS sensor. You wanted to know if the temp sender had 1 or 2 wires. The water temp sender has only 1 wire going to it. The ECT has 2 wires, The IAT has 2 wires and the IAC has 2 wires. I miss read your earlier post I think. I thought you were talking about the air temp sensor having 1 or 2 wires sorry or the confusion Are we still on the right track? replacing the IAT?
alreadydeadford
31
05-09-2021 07:21 PM
Kuskoal
03-26-2010 03:21 PM
meck1
09-15-2004 05:37 AM
