c4 transmission help????
I'm not blaming you, because you've been hoodwinked along with many others that have read this BS info.
People that claim 5 bolt bell housings are pre 1965 are either unaware, dense or have forgotten about early 1965 Mustangs.
Mustang first shown to the general public 4/17/1964 at the NY World's Fair, went on sale nationwide 4/23/1964. FoMoCo called 'em '65's from the get go.
1965 Mustang 260/289/289 HiPo assembled before 8/20/1964 have the 5 bolt bell housing pattern.
1965/72 Ford Passenger Car Parts Catalog ~ F = parts catalog symbol for Mustang.
C3OZ-6392-E .. Flywheel (bell) Housing- 5 engine mounting holes / Marked C3AA-6394-C
Just because Ford introduced a new model a few months early doesn't change the fact that 5 bolt bell small block engines were discontinued prior to 1965. I stand by my statement. With all due respect, Bill, you're really reaching to try to discredit me for some reason, and your motivation escapes me.
I DID NOT try and discredit you, quite the contrary. I said I'm not blaming you, because you've been hoodwinkled like a lot of other people.
The fact is 1965 Mustang introduced 4/23/64 and before 8/20/64 came with 5 bolt pattern V8 bell housing.
The hood, steering wheel, horn ring, turn signal switch, the V8 timing cover and the waterpump are also different before 8/20/64.
Hey all ,, sorry its been while but I do have some more info... I have an 87 block. I did pull all of my block numbers so I know what im working with now. I did end up picking up the c4 tranny. it has a flexplate with it now. haven't really looked at it too much yet, haven't had too much time to mess around with the truck..
but since it is a 87 engine ,,, I do need a 50 oz flywheel ,,correct? should I get a 157 tooth?
thanks again guys ...
DoubleJ
01-22-2016 09:42 AM
LEADSLED52
03-19-2011 06:39 AM
