1951 Ford F1 resurrection, jag IFS LT1, EFI, T56, etc
#317
#319
back at it today, frame painted satin black
Also cut the front jag springs 1 coil before getting ready for paint. With the engine in the chassis the suspension was barely off the bump stops and I needed another 2" in drop to get the suspension where it should be. There was 1/4" in plastic spring spacers that were removed and with this one coil removed it should do the trick. Actual thickness of the 1 coil is 1" since most of it was flat.
More painting and then chassis assembly on the way!
#321
#322
Thanks, things should move along chassis wise pretty quick since most of the fabrication work was already done. Still a few unknowns to deal with but nothing major.
Thanks Ben, weather has been cooperating on my days off so far. Did you ever get your truck on a rack to see what the front end noise was?
#324
#326
Watch on the Jag, IIRC they use GM pattern but the stud diameter and center hole is different, make sure the adapters accommodate, or you may need to get the centerholes machined on one of the pairs. Nice to only have to carry one spare, you could even use a GM space saver spare.
#327
#328
Good info Slick. Can we see a picture? For potential future builders considering a Jag IFS, the XJS ran the same basic suspension later (thru 1996) than the XJ6 and XJ12 where 1987 was the last year. IIRC being that the XJS was a V12 (heavier engine), it has stiffer front springs and a larger diameter and therefore stiffer stabilizer.
Are you good with the stiffer springs?
#329
Just don't skimp, buy good ones and they will be fine. Remember they will add tread width tho.
It would be nice to have hub centric adapters but I am sure they would be a custom build. For that money I could just get the front hubs redrilled and swap to the 8.8 rear.
#330
