1951 Ford F1 resurrection, jag IFS LT1, EFI, T56, etc - Page 26 - Ford Truck Enthusiasts Forums
  #376
Old 08-15-2014, 08:08 PM
Poppachubby's Avatar
Poppachubby Poppachubby is offline
Poppachubby is starting off with a positive reputation.
Wheel size
What size are these wheels? They look good! That's about the size i would like to put on my F1
Quote:
Originally Posted by drptop70ss View Post
Thanks, I was worried about being too low but I think it looks pretty good. Just to confirm I had to check one of the real wheels at that height.
I like it, but not any lower, so (dont yell at me) I am going to flip the shackles back over (3" higher), get the bed installed, and then adjust to this height with blocks as needed. New shocks will now fit as expected. I need to weld this stuff in place so I will stop messing with it. C notch may not be needed, there is 3 1/2" travel available with the rear axle at this height, maybe that is enough? Made patterns today to make the notch but I will save them.
  #377
Old 08-15-2014, 08:49 PM
drptop70ss's Avatar
drptop70ss drptop70ss is offline
drptop70ss is a splendid one to beholddrptop70ss is a splendid one to beholddrptop70ss is a splendid one to beholddrptop70ss is a splendid one to beholddrptop70ss is a splendid one to beholddrptop70ss is a splendid one to beholddrptop70ss is a splendid one to behold
Quote:
Wheels are 18x8s, tires are 235/50/18s, all came from a 2011 mustang GT.
  #378
Old 08-19-2014, 06:41 PM
'77 Dent's Avatar
'77 Dent '77 Dent is offline
'77 Dent is starting off with a positive reputation.
subscribed. amazing work. Makes me want to tear into my '77 dent.
  #379
Old 08-19-2014, 10:18 PM
drptop70ss's Avatar
Quote:
Thank you, I am no pro but I do the best I can. Now get out there and tear it up, just have a plan and take care of once section of the truck at at time.
  #380
Old 08-20-2014, 09:53 AM
'77 Dent's Avatar
We actually just got through a restoration about 4 years ago and the 300 I6 is still running strong. Trying to decide if I should wait for it to start going out then do the restomod. I want to do crown vic front and rear suspension and the crown vic motor/trans/rear end. but anyways don't mean to derail this thread. keep up the good work.
  #381
Old 08-20-2014, 12:53 PM
drptop70ss's Avatar
LOL its already derailed until I get my cab back! I promise it will be completed, just not as soon as I hoped. Meanwhile I will keep cranking on truck #2.
  #382
Old 10-28-2014, 07:50 PM
drptop70ss's Avatar
Update sort of
Had to move the chassis to another bay for its winter slumber, cab chop is mostly done but my buddy like myself does most of his work while snow is on the ground. So this truck build will be paused for a few months until all the cab is back. Meanwhile I will continue on the truck #2 build.
  #383
Old 10-28-2014, 09:44 PM
mustangmike6996's Avatar
mustangmike6996 mustangmike6996 is offline
mustangmike6996 has a good reputation on FTE.mustangmike6996 has a good reputation on FTE.
Nice.
Are you planning on staying with those wheels?
  #384
Old 10-28-2014, 09:53 PM
drptop70ss's Avatar
Thanks, yes I will be running those wheels and tires.
  #385
Old 10-29-2014, 11:44 AM
Rollingmenace Rollingmenace is offline
Rollingmenace is starting off with a positive reputation.
Looking good Dave... Two builds at once lol your a man of many projects just like myself.... I plan on starting my build around end of December ... Love the GT wheels I'm considering a set myself... I haven't found too much info on them I know their alloy ... Do u think they would polish up.... And what did you do to fit them on the jag front??? Adapters ??
  #386
Old 10-29-2014, 12:02 PM
drptop70ss's Avatar
Thanks!
I broke one of my own car building rules by doing two builds at once, but this is the first time I farmed out something so I cant just sit around waiting.
I would think the wheels would polish up, I like them silver. I have another set of chrome wheels as well similar style but not exactly the same. I think there may be a picture of them somewhere in this build thread, if not I can find one. They were going to be for truck #2, but I like the torque thrust Ds as well.
Wheels are on with adapters. If the tire side clearance is too tight I will send out a set of jag hubs to get plugged and redrilled for the 4 1/2" Ford pattern so the adapters would not be needed. Gotta have Ford wheels even if the engine is an "off" brand.
  #387
Old 11-06-2014, 09:47 PM
Jeff and Nicolle's Avatar
Jeff and Nicolle Jeff and Nicolle is offline
Jeff and Nicolle has a great reputation on FTE.Jeff and Nicolle has a great reputation on FTE.Jeff and Nicolle has a great reputation on FTE.Jeff and Nicolle has a great reputation on FTE.Jeff and Nicolle has a great reputation on FTE.
Dave, I have been off my truck project for two yrs, but am back!
I got to get my bearing straight, blow off the dust, and pick up where I left off.
I am admiring your progress and the filler in the fender looks great!
  #388
Old 11-06-2014, 10:17 PM
drptop70ss's Avatar
Thanks, good to see you are back at it! I am looking forward to some updates, get that thing on the road
I am trying to keep pushing on truck #2 but lately I just cant seem to catch a break, my tow vehicle that I need for snow plowing in the winter is now leaking gas, I dropped the tank but all the lines are junk so I have to spend some time fixing that.
I also got distracted this last weekend and dragged home this 1956 dodge that has been sitting since 1983. It is a literal basket case but too solid to not grab and save, probably be a frame swap build but not here since it isnt a Ford.
I have a lot of outside commitments for the next few weeks so probably no new updates on my end for awhile.
  #389
Old 11-06-2014, 10:23 PM
I am gonna build an addition on my garage, first, so I can have more room to work on the truck. So I probably won't have any updated for a little while myself. But you got some good stuff goin on there!
  #390
Old 11-06-2014, 10:45 PM
drptop70ss's Avatar
Ha we think alike, already planning an extension on my garage as well, just have to fit it in between everything else.
another reminder for those installing the jag IFS drptop70ss 1948 - 1956 F1, F100 & Larger F-Series Trucks 11 11-12-2016 08:33 AM
Lets do it again! 1951 Ford F1 LT1 supercharged, 4L80E, EFI, jag IFS, etc.. drptop70ss 1948 - 1956 F1, F100 & Larger F-Series Trucks 420 11-09-2016 10:41 PM
F1 latch repairs, fix the sag and make them work! drptop70ss 1948 - 1956 F1, F100 & Larger F-Series Trucks 35 11-05-2015 09:43 PM
LED replacement bulb info, dont bother with them drptop70ss 1948 - 1956 F1, F100 & Larger F-Series Trucks 21 08-19-2015 06:40 PM
1951 radiator support sheetmetal pieces, mounting question drptop70ss 1948 - 1956 F1, F100 & Larger F-Series Trucks 5 07-27-2015 04:00 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
