1951 Ford F1 resurrection, jag IFS LT1, EFI, T56, etc - Page 11 - Ford Truck Enthusiasts Forums
  #151
Old 12-27-2013, 07:48 PM
drptop70ss's Avatar
drptop70ss drptop70ss is offline
drptop70ss is a splendid one to beholddrptop70ss is a splendid one to beholddrptop70ss is a splendid one to beholddrptop70ss is a splendid one to beholddrptop70ss is a splendid one to beholddrptop70ss is a splendid one to beholddrptop70ss is a splendid one to behold
Quote:
Originally Posted by 49willard View Post
I agree!
At this point in the build the thought may come to mind "now remind me again, why did I give up on the stock fuel tank"?
Nah, we got room for the pipes to between the tank and the springs for the pipes, will be doing some creative cutting and welding on the camaro tail pipes. Rather have reliability with the in tank fuel pump for the FI, and not hear the gas sloshing around behind me. Only loss will be the lack of a place for the spare tire but I may just mount it in the bed.
  #152
Old 12-27-2013, 09:37 PM
49willard 49willard is offline
49willard has a great reputation on FTE.49willard has a great reputation on FTE.49willard has a great reputation on FTE.49willard has a great reputation on FTE.
  #153
Old 12-27-2013, 09:47 PM
I was not able to add text to the above post/picture, however, I would certainly agree that some creative cutting will be required!
I do agree that converting the original tank to FI has its challenges.
  #154
Old 12-28-2013, 12:19 PM
drptop70ss's Avatar
Ha!<p>Pictures can be deceptive, another reason never to buy a car sight unseen!<p>Plenty of room for tail pipes back there as you shall see
  #155
Old 12-29-2013, 11:37 PM
1958 Ford F250's Avatar
1958 Ford F250 1958 Ford F250 is offline
1958 Ford F250 is starting off with a positive reputation.
Talking Cool !!!!
Quote:
Originally Posted by drptop70ss View Post
Exhaust will have full tail pipes straight out the back, I dont want exhaust noise inside the cab, just out the back. I must be getting old, rather have a comfortable ride and be able to have a conversation or listen to the radio. No more side dumps for me.
I Agree, less noise in the cab more noise out the rear.... not sure how old you are but I'm 40 yrs old and I have also gained the same idea, I would rather listen to the radio or have a conversation than hear all that Racket... in my 20's & some of my 30's I would have disagreed with you but not now. It's FUNNY how LIFE WORKS OUT.. HUH !!!!
  #156
Old 12-31-2013, 02:41 PM
liljohn320 liljohn320 is offline
liljohn320 is starting off with a positive reputation.
Subscribed
  #157
Old 12-31-2013, 02:49 PM
drptop70ss's Avatar
Thanks, hope I can make it worth reading!
It will be a bit before another update, winter has hit with a vengance and it is beyond COOOOOOLD here. I need to drop some plastic to wall off part of the building so maybe I can keep a little heat in an area. <p>Exhaust is now done on both sides other than the tail pipes and I am moving on to some rust repair on the cab if I can keep my feet warm enough.
  #158
Old 12-31-2013, 03:36 PM
Talking AAAAHHHHH !!!!!! "FLORIDA"
80 degrees with a slight Breeze... Clear Skys with maybe a few Puffy White Clouds.... and 70 degrees at night with a cool breeze while a nice walk in the neighborhood. LOL... Hope it Warms up for you.....
  #159
Old 01-02-2014, 11:32 AM
AXracer's Avatar
AXracer AXracer is offline
AXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud of
Turned down tips reduce the sound a lot. A number of the lots we use for autocross have noise restrictions so they take sound readings. Adding turned down tips is a tried and true way to lower the sound level on a too loud exhaust.
  #160
Old 01-02-2014, 03:17 PM
Quote:
Since I have SS cherry bombs, I exit out the back and did turn downs. I have not run the engine in the chassis, only on the engine dyno. Noise level TBD
  #161
Old 01-02-2014, 03:18 PM
Wolfracing Wolfracing is offline
Wolfracing is gaining momentum as a positive member of FTE.Wolfracing is gaining momentum as a positive member of FTE.
That looks very nice and clean! Pretty.
  #162
Old 01-02-2014, 05:42 PM
drptop70ss's Avatar
That is one fine looking chassis!<p>
I guess it depends on your engine, but based on my experience with cherry bombs, let alone turndowns, that is going to be just a bit loud.
My last 69 camaro with a healthy 350 and a full dual system with cherry bombs was loud enough that I decided not to use cherry bombs on my current build. I leave for work early in the AM and that thing was loud from the time it fired up. I may use em on the next build but I will put them on with clamps so I can get them off if they are more loud than cool. Turn downs kick up enough dust and dirt that I avoid them as well, it is amazing the amount of small gravel that a set of turn downs can kick up. I prefer to go straight out the back or angled down at the sides but away from the ground.
  #163
Old 01-02-2014, 06:53 PM
We will have to see if it is too loud. I had a set on a 74 F100 with a 360. It was not too loud but sounded good if you got on it. The engine on Willard is a clone for the GMPP 383HT which is a lower reving high torque engine. It is not a screamer. The cherry bombs, which are the longest available in ss, are not welded in, however, I did look to see if I could find a non offset inlet to outlet muffler in 304SS without success. The tips are angled back at about 135 degrees.
  #164
Old 01-02-2014, 09:58 PM
drptop70ss's Avatar
Agreed you will not know until you fire it. Different engines have different sounds. I had a nova SS with a 400 small block and thrush straght though mufflers, sounded great. Swapped to a 396 big block and it could be heard down the street with the same mufflers. Changed them out after enough neighbors complained.<p>Your tips look clamped on so you can always turn them away from the ground as needed. I am planning on a rear roll pan so I will most likely have the exhaust tips coming out under it or notched into it.
  #165
Old 01-02-2014, 10:04 PM
Cherry Bomb
I First had a Cherry Bomb on my 58 F250 292 Y BLOCK 4.8L and it was NOT too Loud at all, actually sounded pretty Good, I changed it to a FLOWMASTER 40 Series only cause I liked the sound Better. FYI....
Lets do it again! 1951 Ford F1 LT1 supercharged, 4L80E, EFI, jag IFS, etc.. drptop70ss 1948 - 1956 F1, F100 & Larger F-Series Trucks 420 11-09-2016 10:41 PM
F1 latch repairs, fix the sag and make them work! drptop70ss 1948 - 1956 F1, F100 & Larger F-Series Trucks 35 11-05-2015 09:43 PM
LED replacement bulb info, dont bother with them drptop70ss 1948 - 1956 F1, F100 & Larger F-Series Trucks 21 08-19-2015 06:40 PM
rear cab to frame measurement needed drptop70ss 1948 - 1956 F1, F100 & Larger F-Series Trucks 11 04-03-2014 11:02 PM
"firestone" heater for my 51 F1? drptop70ss 1948 - 1956 F1, F100 & Larger F-Series Trucks 4 12-31-2013 10:33 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
