20 inch Wheel on a 2WD? - Ford Truck Enthusiasts Forums
6.2L V8 Discuss the 6.2L V8
Old 10-07-2013, 04:52 PM
judithgap's Avatar
judithgap judithgap is offline
judithgap is starting off with a positive reputation.
I have a Buddy who has a 2011 F250 2 wheel drive that would like to have the 20 inch wheels and tires (275/65/20) from my 2014 F350 4x4.
Can anyone tell me if the will fit on a 2 wheel drive without do any modifications?
Old 10-10-2013, 03:20 PM
Powelligator's Avatar
Powelligator Powelligator is offline
Powelligator is starting off with a positive reputation.
Bolt pattern is the same so you should be fine. Only thing that might be funky is the center trim ring that goes around the front hub on the 4X4 will be wide open on the 4X2.
The larger tire diameter will goof up the 4X2's speedometer/odometer, but it'll still run fine.
-Joe
Old 10-10-2013, 05:31 PM
judithgap's Avatar
-Joe
Thanks for the info.
2016 OEM Ford F350 20inch Aluminum Wheels and Tires wbymag Ford Truck Parts for Sale 0 10-18-2016 04:27 PM
2wd lift kit the same as a 4wd lift? Jeremyrj1995 1987 - 1996 F150 & Larger F-Series Trucks 17 06-12-2014 01:09 PM
STEEL INNIE RIM WIDEN dynamic 1948 - 1956 F1, F100 & Larger F-Series Trucks 9 05-08-2012 06:33 AM
anyone lowered??? rat49f6 1999 to 2016 Super Duty 43 08-15-2011 12:15 AM
Steering Wheel Shimmy grndpndr2 6.7L Power Stroke Diesel 7 10-09-2010 06:21 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
