Advice for purchasing an F4 or bigger truck
Abe, I have to disagree about the F6- F600, the two speed rear does not add a higher gearing, it adds a lower than granny gear. The F-5 came with either a 5.83 or a 5.14 (which is what I have) The F6 2 speeds were 5.83/8.11 or 6.33/8.81. So the F6 will give you more low end pulling power, but the same, and in most cases lower highway speeds.
The Dana 70 was a very easy swap.
Yeah, the 272 will give you a bit more RPM than the flathead. A safe cruising RPM for that would be about 3200, wouldn't want to run it much more than that. With 8R19.5 wheels that would top you out at about 55mph.
I got the 4:10 Dana 70 out of a '69 F350 and it came with 16.5" stud piloted wheels, poor tire selections. I found 16" stud piloted wheels and have a better selection of tall tire sizing. From what I've learned, the Sterling with hub pilot would have been a better, same cost, choice. Perhaps research would have given me other Dana options. I need tall tires on the rear to match the low profile tires that I will install on the Firestone 19.5" that I am running on the front.
on
That would give you approx 40" diameter, so at 3200 RPM it would give you about 65MPH. To run 60, you would be at about a much safer 2975 RPM. Of course you do realize how rare both the wheels (need a 22.5 x at least 7" 5 lug) and that tire size are?
pheasantfarmer
55
06-22-2011 11:43 PM
blockerboyscustoms
21
02-18-2009 11:08 AM
