'62 headlight knob - Ford Truck Enthusiasts Forums
1961 - 1963 F100 Unibody 1961, 1962 and 1963 Ford F100 Unibody trucks
'62 headlight knob
Old 10-07-2013, 01:23 PM
62ESQ 62ESQ is offline
62ESQ is starting off with a positive reputation.
'62 headlight ****
I decided to start replacing broken dash ***** on my 62 unibody and am having a heck of a time. I saw a prior post by Bill explaining how to remove the headlight **** and stem by pushing the button on the top of the light switch and pulling the **** stem all the way out. He wrote that the new **** and stem are then pushed in until a click it heard. So yesterday I removed the old **** and stem and it came out just fine, but when I try to put the new one in, there's no click. The new one and old one look essentially the same. Same length I think. They look so close but could be just a hair different in length, maybe an 1/8 of an inch or less. I tried installing the new one multiple times to see if I'm putting it in wrong but no go. The old one clicks in every time. Have any of you run into this when replacing the old ***** with new repros?
Old 10-10-2013, 04:37 PM
Ok, so I went to the Truck Shop in Orange where I got the **** and stem and the sales guy was nice enough to bring out a '62 headlight switch. Of course, the stem clicked right in. Went back home and tried again, but still not getting it. What's worse is I can't figure out what I'm doing wrong. When I put the new stem in, I can feel it hit the spring resistance and when I push it clicks the lights from high to low to off, but then it slides right out. It doesn't grab anything.
Old 10-11-2013, 02:59 PM
NumberDummy's Avatar
NumberDummy NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
Uh huh, that's what they told you the switch was from, but was it? Probably not.
Truck Shop sold you the wrong **** & shaft. Measure your original, compare with these two.
C1TF-11661-B .. Headlamp Switch **** & Shaft- 2 1/4" long: 1961/62 F100/1100.
C3TZ-11661-D .. Headlamp Switch **** & Shaft 3 3/16" long: 1963/66 F100/1100.
Parts cluck @ Truck Shop only going by what their repro parts catalog application is. I doubt they have the 1957/63 FORD Truck Parts Catalog to verify.
How do I remove the headlight switch knob??? atomicjoe23 1973 - 1979 F-100 & Larger F-Series Trucks 28 07-12-2015 07:52 PM
Dash Knobs Shadowrider123 1961 - 1966 F-100 & Larger F-Series Trucks 12 09-08-2014 05:56 PM
Light switch instl. problems on 52 F1 tractormanbill 1948 - 1956 F1, F100 & Larger F-Series Trucks 5 12-30-2013 09:04 PM
How to remove dash knobs on my 59? Vsanzbajo 1957 - 1960 F100 & Larger F-Series Trucks 8 12-22-2013 02:20 PM
NEED HELP FINDING Acuating knob "o" ring and other HD hub parts 1976HighBoy 1973 - 1979 F-100 & Larger F-Series Trucks 9 09-05-2012 05:31 PM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
