1997 expedition dies after starting - Ford Truck Enthusiasts Forums
Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator
Old 10-07-2013, 12:39 PM
jawsok jawsok is offline
jawsok is starting off with a positive reputation.
1997 expedition 4.6l 4wd starts and then dies almost immediately. Any ideas on where to start?
Old 10-07-2013, 01:31 PM
timbersteel's Avatar
timbersteel timbersteel is online now
timbersteel has a good reputation on FTE.timbersteel has a good reputation on FTE.
Any tune-up performed? Sounds like weak fuel pressure.
Old 10-07-2013, 01:40 PM
alloro alloro is offline
alloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to behold
Once it starts, slightly press on the gas pedal to raise the idle. Does it still stall then, or only at idle?
Old 10-07-2013, 02:37 PM
Icefan71 Icefan71 is offline
Icefan71 has a good reputation on FTE.Icefan71 has a good reputation on FTE.
Quote:
I had the same problem. If I gave it gas it would stay running. If I let it idle it would die. I had a bad IAC, idle air control valve. I replaced it and that fixed the problem.
Old 10-07-2013, 09:01 PM
It will run rough if I press on the gas pedal. I will check on everything everybody told me. Thanks on all comments. I will let you know in the next few days
Junkyard parts richsoucie Expedition & Navigator 4 04-06-2015 04:51 PM
Taillights richsoucie Excursion - King of SUVs 8 03-25-2015 09:57 AM
Truck cuts out when spinning Epd444 1994.5 - 1997 7.3L Power Stroke Diesel 17 12-22-2014 12:55 AM
1997 4 cyl Ranger died and won't start mskeen Ranger & B-Series 5 07-10-2014 11:43 AM
1997 expedition steering pump sensor replacement signal0 Expedition & Navigator 0 06-27-2014 08:44 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
