Coolant leak HELP!!
Coolant leak HELP!!
My father's 2001 7.3 is leaking coolant out of a metal tube located on the front passenger side of the block next to the water pump. I cannot see where this tube goes on the to of the motor due to the A/C bracket. What is this tube and why is it leaking? Any help would be appreciated. (it pours antifreeze when running) Thanks
It sounds to me like you are describing the water-in-fuel drain tube that comes down the front of the engine on the passenger's side and stops about half way down. It is a small 3/8" metal tube.
Are you sure it is not fuel rather than coolant?
__________________
Specializing in Viton® o-rings and leak repair kits for the 7.3L and 6.0L diesels
(970) 368-4455 aka guzzleguzzle's Mods & Maintenance website
The drain tube comes directly from the fuel bowl drain valve. No way would coolant come from that tube.
__________________
