Replacing bushings and King pins - Ford Truck Enthusiasts Forums
Old 10-06-2013, 06:22 PM
egg collector egg collector is offline
egg collector is starting off with a positive reputation.
I am replacing my king pins and bushings on my 1960 f100 truck. I have read here I will need to drill out the bushings before the new king pin will work. I already have one set of bushings in and did not want to force the pin in so I stopped. What size drill bit should I use and any other suggestions.
thanks
egg
Old 10-06-2013, 08:46 PM
oldebrush's Avatar
oldebrush oldebrush is offline
oldebrush is starting off with a positive reputation.
Dear Egg,
Please, DO NOT use any drill bit at all on those bushings.
You need to "ream" them to size, and that needs to be done with the proper reamer that will align the finished bores together. If you don't have the right tool, take your spindles to a shop to have the job done. Anything less will result in failure and more expense.
Also, there is a hole in the side of each bushing which must be lined up with the grease fitting holes in the spindle. If you don't do this, you can't lubricate the new bushings and pins.
Hope I caught you in time.
Aloha, Tony
Old 10-07-2013, 07:41 AM
Thanks, for the advice. I knew about the grease hole. Will look for a shop.
ec
Old 10-08-2013, 07:42 PM
spurredon's Avatar
spurredon spurredon is offline
spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.spurredon has a great reputation on FTE.
Shops that take care of big trucks should have the tools needed for the job.
Old 10-09-2013, 08:51 PM
Found a local shop that did a great job. They had to look for their reamer, they had not done one in a long time.
Thanks for the help.
ec
King pin rebuild Santiagoeford 1961 - 1966 F-100 & Larger F-Series Trucks 13 07-19-2015 01:27 PM
Misc Bushings jvmcc 1948 - 1956 F1, F100 & Larger F-Series Trucks 5 05-24-2014 04:18 PM
Help needed with Spindle bolt locking pin removal longm Ranchero & 1961 - 1967 Econoline 3 09-27-2011 07:39 PM
King Pin replacement LotusJoe Ranchero & 1961 - 1967 Econoline 2 09-23-2009 11:58 PM
King Pin Bushings cujo8 Brakes, Steering, Suspension, Tires, & Wheels 7 08-18-2006 06:59 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
