Anyone running Atlas 40 and tunes from Matt?
Atlas 40 with SRL Extreme here. I'm sure you've seen my mods by now Sean. Average MPG with 50% in town and 50% highway is usually around 14.5 MPG. Average when I drive mostly highway is about 18.5. Pure highway I've pulled 22.5. I'm sure these numbers would be better yet without a lift and the big M/T's. I also definitely do not drive the truck like an old man. As far as smoke goes I get one small black puff on startup and only get smoke at low end speed with at least 50% throttle. If I put it to the floor at low end speed it'll leave a decent cloud until the turbo clears it up. EGT is generally about 700 cruising down the highway, highest I've seen it with a WOT pull was about 1400.
A stud set is in the plans but not yet.
RANT WARNING
The first spring I owned this truck I did give some guy on a bike a cloud
to inhale. The bozo forced me out into on coming traffic with a stupid
move on his part. I munched the peddle to the floor and for a good
size PUFF. I have found it hard to get any smoke out in most cases.
That time I was at about 30 going up a slight hill and was at 55
before I knew it.
Lesson is if your on a bike in traffic don't be stupid with a 8,000 Lb
truck coming up on you. The thing is it was his stupid move and IF
I had hit him guess who would get the blame.
END RANT
For the most part I also find that Matt's 8k tow tune keeps my
food out of the fuel tank and still gives me a lot of PEP.
Sean
RANT WARNING
before I knew it.
END RANT
Sean
I'm running the Atlas-40 and have run both the 8k Tow and SRL.
For MPG's I do about 75% highway 25% town driving and am pretty solid at a hair just over a calculated 16 mpg and that's for both the 8K Tow and SRL.
Regarding the smoke I do get a little puff on take off if I'm somewhat easy on it and get bit more if I take off hard. But while cruising or idling it's pretty much smoke free.
And then for EGT's: Stock @ 80 mph on a flat highway I would run about 700*-775*. On the SRL tune @ 80 mph and flat road I am getting 575*-650*. On the 8K Tow with same speed I'm seeing about 600*-675*.
Atlas 40 plus the canned SCT 120Hp performance didn't smoke at all for me Is that a problem with the Gearhead tunes in general?
The 60-HP canned Street tune smokes when I get into it, but it's not the boiling cloud of coal that the SRL was...
They'll clean up considerably once it's under full boost (and usually 100+ MPH by that point) but on the takeoff, you don't want to be in the same county.
-blaine
I moved it back to stock until I can get it studded. Self control isn't too hard until you meet that ID10T on the highway... Temper tends to take control of self... . Anyways better safe than sorry....
