Gas Tank
Old 10-06-2013, 09:09 AM
1958 Ford F250's Avatar
1958 Ford F250
1958 Ford F250 is offline
Smile Gas Tank
Hi, I replaced my in cab gas tank and sending unit with a new one on my 1958 Ford F250, since then I am getting gas leaking through the screws, SO I made sure I got a Vented Gas cap and I replaced the screws with new ones. STILL leaking gas out of my screws. Does anyone have any suggestions on what I can DO or put on my screws to seal them up, something that can mix with Gas I guess. I asked about RTV silicone but I was told it will not work with gas, Has anybody else had this problem???? Thanks !!!
Old 10-06-2013, 10:41 AM
theodore/teddy's Avatar
theodore/teddy
theodore/teddy is offline
Refyred
Old 10-06-2013, 06:16 PM
1958 Ford F250
Smile Gas Tank
Theodore/Teddy I see you have a 59, Have you ever had this problem??? Google only get's you so far, I asked here because to see if my fellow Ford's can help. Do you know what to put on these screws that can mix a bit with Gas to seal them up???
Old 10-06-2013, 08:51 PM
theodore/teddy
Refyred
When I transfered my original sending unit into a newer tank between the frame rails. I used non-hardening permatex on the gasket and sealed the threads with Loctite blue thread sealant. It's not easy to see this area now, but I don't see any leaks or seepage down the tank. Not sure if thats by the book, but it's old habit.
When the tank was in the cab it never leaked or smelled, that was noticeable to me.
Good luck in your quest.
Old 10-06-2013, 09:18 PM
1958 Ford F250
Smile Gas Tank
Hi, OK, I'm gonna try the loctite because that I haven't done and sounds like it will really work, for whatever reason this is happening and Old school or not remedies I will try. Thanks for the advice!!! One last thing I see you were able to post a picture of your truck on the threads, do you remember how to do that?? I was able to load my truck pictures into an album that is called "Work in Progress" but I can't figure out on how to post a picture of my Truck on my Post's. By the way I like your 4x4 on the picture looks pretty cool. Thanks again.
Old 10-06-2013, 09:37 PM
theodore/teddy
Refyred
Top left of screen (just below thread title) click "user CP" Once your in your user control panel, go down the left side and click on "edit avatar"
Thats a good lookin 58 you have!
Old 10-06-2013, 10:45 PM
1958 Ford F250
Smile Gas Tank
Thanks !! I appreciate that, I still have quite a bit to go till it is complete but I love driving it around and the response from peaple that see it. OK Thank you for the information on the picture and the Gas tank. Have a Great day!!!!
Old 10-08-2013, 07:41 PM
spurredon's Avatar
spurredon
spurredon is offline
Pretty sure I just used a cork gasket, never have smelled or seen a thing!
Old 10-18-2013, 08:16 PM
economan's Avatar
economan
economan is offline
Who can afford to fill their gas tank up to the top???
therefore this shouldn't be a problem
(heh heh)
Mikie
near Ottawa Canada
58 merc 100 panel & 64 econoline p/u
Old 10-18-2013, 09:03 PM
oldebrush's Avatar
oldebrush
oldebrush is offline
Gas Tank
Use a cork gasket, as "Spurredon" said, and you can add something extra, very small (small enough so they just fit over the screw threads) neoprene "O" rings, on each screw. Then just tighten down evenly, a little at each screw until well seated.
Hope this works for you.
Aloha, Tony
Old 10-19-2013, 12:40 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Originally Posted by 1958 Ford F250
I replaced my in cab gas tank and sending unit with a new one on my 1958 Ford F250, since then I am getting gas leaking through the screws.
Did you replace the sending unit gasket? If not, there's the cause, as you cannot use the old one over again, as cork shrinks with age.
C1TF-9276-A .. In-Cab Fuel Tank Sending Unit Gasket ~ 3.16" O.D. x 2.00" I.D. -.12" thick, (6) 5/32" diameter holes.
Applications: 1957/60 F100/1100 & 1961/77 F100/750 / Whiz to an autoparts store and get one.
GREEN SALES CO. (800-543-4959) & CARPENTER NOS OBSOLETE PARTS (800-476-9653) both have over 100.
Old 10-20-2013, 05:07 AM
1958 Ford F250
Smile GAS Tank
Hi, Yeah mine has one too but the fuel is coming out of the screws Through the gasket, so I'm trying options to seal up the Threads and something that can mix with Gas. Thanks !!!
Old 10-20-2013, 05:09 AM
1958 Ford F250
Smile Gas Tank
(heh heh)
Mikie
near Ottawa Canada
LOL!!! That' Funny, yeah I try not to fill it to the rim but I guess since it still splashes around it hits TOP. Thanks !! for the Laugh.
Old 10-20-2013, 05:14 AM
1958 Ford F250
Smile Gas Tank
Aloha, Tony
Hi, Neoprene "O" rings Huh!!! HHMMM!! That's another good Idea didn't think of that, That may just work fine, I'm gonna go see if I find them that small and try it out also. THANKS!!! I appreciate it.
Old 10-20-2013, 05:17 AM
1958 Ford F250
Smile Gas Tank
Hi, Yes I did replace it with a new one as a matter of fact it's all new Tank-sending unit- Gaskets-Floater ETC.... not sure what happen thier with the gas coming out of the screws. HEY (NumberDummy) I see you are all over the Threads and with alot of GOOD Information, without taking my "YOKE" off my 1958 Ford F250 DANA 60 series Differential would you happen to know what "SPLINE" # count is on my Truck 10,29,30 etc... ????? and what size are my "U JOINTS" ???? Thanks
Quick Reply: Gas Tank
