96 F250 Transmission Type
On the older Ford VIN numbers you used to get the transmission type. I have run the VIN number for my 96 F-250 and I can't get what type of transmission I have in the truck. Is there another ID number on the truck somewhere that I can quickly get this information? It has a 5.8L / 351 engine. I would imagine it is either a C6 or AOD but I want to make sure. I want to do a filter change and fluid change so I need to make sure I am getting the right gasket and filter and also amount of fluid.
Thanks
Thanks
1980 thru today: TRANS code printed on the Certification Label.
1957/79: TRANS code embossed on the Warranty Plate.
1948/56: Transmission type embossed on the Rating Plate.
AOD: 14 trans pan bolt holes / C6: 17 trans pan bolt holes / E4OD: 20 trans pan bolt holes.
davedwards
06-23-2022 12:39 PM
Nathan511
01-03-2017 10:16 AM
rmalottwtes30
03-01-2008 03:23 PM
goodolboy
02-19-2008 09:34 PM
