Need help! Running Bad. - Ford Truck Enthusiasts Forums
Old 10-06-2013, 12:43 AM
AaronSil AaronSil is offline
AaronSil is starting off with a positive reputation.
hey guys i have a 05 f150 5.4 that is giving me issues. it all began one raining day on the way to work when the engine light started flashing. that day the code was for a crank shaft sensor, i replaced it and the next day i was pulling a trailer and the truck began bucking every now and again. threw a code for coils a and f. i swapped the coils. same code. changed the plugs. same code. changed cam shaft sensor.. same code plus p0320. tomorrow i am changing the crankshaft sensor again hoping that maybe it was just a bad sensor. i moved wires from around the AC condenser and all that but still same code... but one thing i have noticed is when it does buck or run rough the ac stops blowing cold.... which is something i haven't seen on anyone's posts... any ideas?
on/off/on - again P0153 code rosadoco Explorer, Sport Trac, Mountaineer & Aviator 2 09-28-2015 08:12 AM
2005 6.0 bucks and surges after start up RockinB 6.0L Power Stroke Diesel 2 07-05-2015 08:36 AM
Ok need some help figuring this out... truck shutdown at the same spot on the road... 69Cobra 1999 - 2003 7.3L Power Stroke Diesel 19 12-19-2013 08:33 PM
Going to take it in...... RBlac 1999 to 2016 Super Duty 19 09-27-2013 01:41 PM
94 F 250 no spark,coil, icm, no luck ajacks 1987 - 1996 F150 & Larger F-Series Trucks 10 07-12-2003 02:45 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
