TruckPastor's 57 Is Alive...sort of
Old 10-23-2013, 01:26 PM
truckpastor's Avatar
truckpastor
truckpastor is offline
Hey all, I finally got my project to run today. My ignition problem seemed to be with a short in the ignition switch wiring causing my points to be continually grounded
That's the good news, now the bad... My starter now just spins but does not crank engine. Perhaps when the motor fired it chewed the teeth off my starter gear? Ill remove it to confirm. This is my luck with projects...fix one thing and break another!
Old 10-23-2013, 01:31 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Coil spring of Bendix inertia starter drive may have broken.
Old 10-23-2013, 01:44 PM
truckpastor
My thoughts too...Is that obsolete part?
Old 10-23-2013, 05:04 PM
NumberDummy
Of course, what isn't for these trucks?!
Available NOS and from autoparts stores. The spring has to be unwound by hand to get to the roll pin that retains it to the armature's shaft.
It takes muscle and a lot of cuss words to rewind that spring back to its normal position. You may be saying mea culpa, mea culpa, mea maxima culpa from the pulpit if anyone other than the lawd hears you.
Old 10-23-2013, 05:43 PM
truckpastor
I've seen the whole drive for sale, but you are saying to get the old one off is a nightmare?
Old 10-23-2013, 05:44 PM
truckpastor
Oh btw the spring was broke but the ends of the gear seem to be chewed
Old 10-23-2013, 05:49 PM
NumberDummy
Unwinding coil spring to access roll pin is as EZ as pie. Rewinding coil spring is a pain in the backside, takes muscle and in many cases, a whole slew of cuss words to get it back to its original position.
They look the same, but looks can be deceiving: There is more than just one of these Bendix inertia starter drives. What engine, 'Mileage Maker' 223 I-6 or 'clackity clack' Y block?
Old 10-23-2013, 06:49 PM
truckpastor
I really should proof read...my spring was Not broke. I've got the 272. The replacements I've seen don't show the spring like mine has, they look enclosed at the end of the drive.
Anyone got any "mini starters" opinions? Saw them for sale too and figure why not save up and upgrade
Tomc750
02-21-2015 08:28 PM
119er
10-17-2013 10:48 PM
Justin3055
06-14-2010 07:42 PM
chappys4life
03-13-2009 02:12 PM
BFOOTER03
07-02-2008 07:30 AM
Quick Reply: TruckPastor's 57 Is Alive...sort of
