Oil opinions. - Ford Truck Enthusiasts Forums
6.2L V8 Discuss the 6.2L V8
Oil opinions.
Old 10-05-2013, 03:43 PM
T diesel T diesel is offline
T diesel has a good reputation on FTE.T diesel has a good reputation on FTE.
Oil opinions.
Best synthetic oil for the 6.2?
Old 10-05-2013, 09:38 PM
LCT LCT is offline
LCT is starting off with a positive reputation.
Amzoil 5W20 Signature Series (100% synthetic). A client who manages a fleet and my brother turned me on to this product. I was a Mobil 1 user then went w/ Amzoil. The intervals are 25,000 miles or 1 year. I use this product now on all of my vehicles. I get their 25,000 mile filter, which provides excellent filtration. Truck runs great as does my other vehicles!
Old 10-05-2013, 09:45 PM
LCT LCT is offline
Spellcheck. AMSOIL.
Old 10-05-2013, 10:33 PM
22rimfire 22rimfire is offline
22rimfire is gaining momentum as a positive member of FTE.22rimfire is gaining momentum as a positive member of FTE.
Not trying to be negative on Amsoil products, I think highly of them, and used thier trans fluid in my last truck, but what would happen if you needed waranty work and the dealer found out you only change oil every 25K? Just sayin. I haven't got to the first oil change in mine yet, but in my previous truck I used Mobile1 and changed every 5K. It had 152,000 miles on it when I traded it in and still ran strong. I'm leaning toward using Motorcraft Synblend with the Motorcraft filter in mine.
Old 10-05-2013, 10:57 PM
Beechkid Beechkid is offline
Beechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud ofBeechkid has much to be proud of
Quote:
Agree- kiss your warranty goodbye ...also if you read AMSOIL's qualifying instructions for those intervals, well, most would not be in compliance.
Old 10-06-2013, 07:20 AM
LCT LCT is offline
I hear what your saying, but my intervals are typically every 6 mths just to be on the safe side. During that time I average 6000-7500 miles, so I know I am fully protected with some of the very best synthetic you can buy. I also throw in their fuel treatment every 3 mths. Vehicles run great.
Old 10-06-2013, 10:55 AM
ATP Pilot's Avatar
ATP Pilot ATP Pilot is offline
ATP Pilot is gaining momentum as a positive member of FTE.
Motorcraft Syn-blend every 5000 miles for me. I like to look around under the beast and do an inspection at that point anyway.
Over the years, going way back for me...I used Quaker state, Castrol, Mobil 1... etc. I have never worn out an engine with any of these oils. I don't keep a motor past 150,000 miles, so i have never had a problem.
Old 10-06-2013, 11:45 AM
Quote:
That's smart!
Old 10-06-2013, 12:46 PM
rvpuller's Avatar
rvpuller rvpuller is offline
rvpuller has much to be proud ofrvpuller has much to be proud ofrvpuller has much to be proud ofrvpuller has much to be proud ofrvpuller has much to be proud ofrvpuller has much to be proud ofrvpuller has much to be proud ofrvpuller has much to be proud of
I plan on using Motocraft for now or until I know for sure I won't have any warranty problems, I used Mobil 1 in my last truck with no problems so if I decide to change I will probably go back to the Mobil 1.
Denny
Old 10-06-2013, 03:29 PM
Flatbed Ed's Avatar
Flatbed Ed Flatbed Ed is offline
Flatbed Ed is starting off with a positive reputation.
I use Mobil 1 5w-30. 76k miles, no problems so far.
I live in Texas. It gets hot down here so I use 5w-30 instead of 5w-20.
Old 10-07-2013, 04:27 AM
Dave HM Dave HM is offline
Dave HM is starting off with a positive reputation.
It is Motocraft every 5000 for me.
The local stealer does it for less than 18 bucks. Plus every 5th change is free.
If this motor was right from the factory, it is one thing I am not going to wear out.
My savings will go to
aftermarket 7 quart oil pan fnfast88 1987 - 1996 F150 & Larger F-Series Trucks 0 12-20-2014 02:28 PM
Oil Pan Nut Torque bvieages 6.0L Power Stroke Diesel 1 08-30-2014 11:46 AM
Oil Question. wheelerg 6.0L Power Stroke Diesel 16 02-02-2014 01:14 PM
Oil Pump akissz 1948 - 1956 F1, F100 & Larger F-Series Trucks 15 04-04-2008 03:48 PM
oil for undercoating 351 power Paint & Bodywork 5 11-04-2004 11:51 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
