Brake petal spongy
Brake petal spongy
Hi I have a 1994 ford f150. The brakes weren't working so I replaced the booster, master cylinder and most of the brake lines, aswell as new calipers and pads in the front. I have proper fluid levels and I have bled the brakes front and rear. However the pedal goes all the way to the floor before the brakes start working. Also the e-brake cable just snapped. Any suggestions on what the problem is? Thanks.
2 for the rear wheels
1 for the abs/brake propositioning block (on d/s frame rail, under firewall)
2 for the front wheels...
bleed it, just like the rest .
My abs and brake light were on. I bled the abs module and then the two fronts. No change in brake pedal. All the way to the floor before the brakes start working. Only difference is my abs and brake light aren't on anymore.
Ben24
15
10-08-2013 06:48 PM
handsomerob
38
04-05-2008 09:04 PM
