2010 250 Coolant test?
Hi All,
I am new to the forum and have to say there is certainly a wealth of information here! I have a new to me 2010 f250 lariat with the 6.4. I have been reading the forums quite a bit learning about the maintenance etc. One question I have is regarding the coolant. I read some posts that the coolant needed to be tested with strips. I found a TSB on the issue but it doesn't seem to apply to the 2010 6.4, can anybody clear this up for me?
Thanks!!
Thanks!!
Hi All,
Thanks!!
Thanks!!
If you have Gold (not yellow, not red, not orange) you may need to test it.
Here is how...
Another thing, I looked at the TSB you mentioned 09-8-5 and it states:
2003-2005 Excursion
2003-2008 E-350, E-450, E-550, F-Super Duty
so since mine is a 2010 I am guessing it doesn't apply? I also found a "diesel operating and maintenance tips" sheet on the Ford website that states the check should be done for the 6.0 and 6.4 but it doesn't say anything about years....now I am totally confused!!!!!!!
2003-2005 Excursion
Go to NAPA, ford usually does not have the strips. At NAPA they usually have them in a large quantity but that is the easiest solution.
You can test at the degas bottle with the coolant being less than 110F.
You are mostly concerned about the nitrite level.
See the document I have posted.
Thanks Senix, do you have a part number for those?
The Ford part # for Rotunda is on the PDF sheet. For the Napa strips
the box says 524106. Other side of the box says Napa 4106.
Just ask for coolant test strips for diesels.
Also be sure you get a long stem thermometer so you can ensure you coolant is below the 110F.
Long needle nose pliers to dip the strip in the degas bottle.
I didnt realize that the new Orange coolant was still a nitrate charged coolant.
Fordfenders, disregard my posts above, they are for GOLD coolant, which was in the 7.3, 6.0 and maybe the 6.4(?).
Looks like senix has you covered. It should be a similar procedure to my video, but I cant make any promises because I've never done it on a 6.7L.
Well, I went to NAPA, they ordered the strips for me, should be here Monday afternoon.... I went and picked up a thermometer as well. I noticed on my degas bottle that it states to use the "gold" coolant so I guess that answers that one! Thanks for the tips guys, i will keep you posted....
