2002 f250 v10 gas
There is! On the inside of your fuel line, at the point where it connects to the filter there are prongs that need to be pushed away from the shouldered part of the filter. The tool goes inside the fuel line and spreads the prongs away from the filter. You can get one at any part store for around $10 I believe.
with out doubt unless it's one that has the push button slide on the slide on fitting,here is what I use for every brand now Search results for: 'fuel line tools'
youknowitdadio
07-01-2018 01:23 AM
