head studs, etc. - Page 6 - Ford Truck Enthusiasts Forums
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
head studs, etc.
  #76
Old 12-07-2013, 05:36 PM
427 fordman's Avatar
427 fordman 427 fordman is offline
427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.
Means it's out of the truck, I'd probably pull the heads too. It would make valve spring changing a lot easier for sure.
  #77
Old 12-09-2013, 08:47 AM
OldWoodsDiesel's Avatar
OldWoodsDiesel OldWoodsDiesel is offline
OldWoodsDiesel is gaining momentum as a positive member of FTE.
that's kind of what I was thinking. there should be no need for that special tool then, right? ...maybe just a different special tool :-)
I was thinking more about this over the weekend, though and the counter-argument for just leaving the heads in place is that if a compression test comes up OK on the engine, there really should be no issues with the valves or sealing surfaces. this engine does have what always sounded like a valve tap to me, so i'm trying to figure that out, but I guess the compression test is first...
2001 V10 freeze plugs 427 fordman 1999 to 2016 Super Duty 1 12-14-2014 05:53 PM
V10 Exhaust Studs avgjoe 1999 to 2016 Super Duty 7 11-14-2014 04:41 PM
Where to buy stainless exhaust studs besides dealer? Soarer 1987 - 1996 F150 & Larger F-Series Trucks 12 02-18-2014 10:41 AM
Ex manifold studs 02 v 10 stan'37 Modular V10 (6.8l) 3 01-25-2014 02:39 PM
studs different sizes front to rear- how to correct? hasteranger 1973 - 1979 F-100 & Larger F-Series Trucks 4 10-19-2010 09:15 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
