head studs, etc. - Page 3 - Ford Truck Enthusiasts Forums
head studs, etc.
  #31
Old 10-11-2013, 04:21 PM
ReBilld's Avatar
ReBilld ReBilld is offline
ReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to behold
Good deal Darin. I'd like to do studs and stuff now, but that's gonna have to wait.
  #32
Old 10-11-2013, 06:47 PM
427 fordman's Avatar
427 fordman 427 fordman is online now
427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.
I can see that Bill. You have enough on your plate as it is! I know how that goes, I'd have liked to be able to do them last winter.
Picked up the oil at napa today. 80 bucks for 4 gallons, not bad.
  #33
Old 10-11-2013, 07:45 PM
oldbird1965's Avatar
oldbird1965 oldbird1965 is offline
oldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to behold
Perfect!!!
  #34
Old 11-24-2013, 04:39 PM
I got the passengers side done this weekend, studs and springs. I only had to raise the motor on that side for one stud, then did all the springs while I had it up. No other work needed to get at the studs on that side. I didn't work too hard. Didn't have much time on it yesterday.
I should get the other side done on thanksgiving, then get it back together by the weekend.
  #35
Old 11-24-2013, 05:30 PM
DIYMechanic's Avatar
DIYMechanic DIYMechanic is offline
DIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to behold
Wow, you're moving right along Darin! I'm glad to hear you're making good progress. You'll have that thing done in short order at this rate.
  #36
Old 11-24-2013, 11:46 PM
You remind me of my roommates at college. They partied 24/7 and carried a 4.0 average. Me, I was in the library studying my *** off!! Get my point, .
I'm glad your making such good progress Darin.
  #37
Old 11-25-2013, 01:04 AM
ReBilld's Avatar
Hurry up and get those studs and springs done so you can start the other little project!
  #38
Old 11-25-2013, 05:01 AM
Thanks guys, I'm gaining. Seems I pushed my back more than I thought. Hopefully it recovers some by thursday or I may not get done for a while.
  #39
Old 11-25-2013, 09:50 AM
nossliw's Avatar
nossliw nossliw is offline
nossliw has a great reputation on FTE.nossliw has a great reputation on FTE.nossliw has a great reputation on FTE.nossliw has a great reputation on FTE.nossliw has a great reputation on FTE.
Hey guys,
I didn't want o hijack this thread at all, just had a quick question.
What do you all consider the cutoff for when studs/springs and pushrods are required? I say cutoff as in turbo/ injector size? I was not planning to do this untill the motor needed to be rebuilt, but are stage 1's and a S366 screaming for this upgrade to be done?
I know they are 1000$ insurance against HG failure, but are they truly needed for a very mild motor/injector/turbo combo that is driven 95% of the time in a stock tune?
Just thought I'd ask since you all are doing it :-)
  #40
Old 11-25-2013, 09:56 AM
Well, with my stage ones I can hit 40lbs of boost on the S366. From what I've read anytime you start getting above 35 you better have studs in. I was backing out on hills from high boost last year towing instead of egt's.
If you're just daily driving in a stock tune, you'll be fine. You just don't want to push the bigger boost/backpressure numbers without some studs. Springs are a little stronger for better valve control, and the pushrods are stronger also.
  #41
Old 11-25-2013, 10:45 AM
nossliw's Avatar
Thanks for the info. I will see what we are actually pushing with the s366 when it goes in. Good to know the cut off boost pressure!
Thank you!
  #42
Old 11-25-2013, 02:02 PM
cowmilker08's Avatar
cowmilker08 cowmilker08 is offline
cowmilker08 has a good reputation on FTE.cowmilker08 has a good reputation on FTE.cowmilker08 has a good reputation on FTE.
Sorry to continue the hijack... but isn't the drive pressure the real issue? I am wondering since the s366 will have a better drive pressure ratio you may be ok at 40 psi boost with an s366, but not with a stock turbo over 35 psi. Just a thought...
  #43
Old 11-25-2013, 02:25 PM
arkredneck's Avatar
arkredneck arkredneck is offline
arkredneck is starting off with a positive reputation.
Do the valve springs allow you to rev it higher?
  #44
Old 11-25-2013, 04:46 PM
Phil, I'm no turbo expert, but this is how i understood it. From what I've read it is the backpressure to be worried about, but its gonna be at least 1:1 with the boost, and the same 35 or so is pushing your luck with the stock head bolts. A head gasket will let loose eventually there.
As far as revving higher with the new springs, if your tuning allows it, probably. Basically though they just control the valvetrain better with more seat and open pressures.
  #45
Old 11-25-2013, 05:13 PM
strokin'_tatsch's Avatar
strokin'_tatsch strokin'_tatsch is offline
strokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud ofstrokin'_tatsch has much to be proud of
Quote:
That depends on how many RPMs you plan to run. Realistically, you're not going to spin insane RPMs without running a pretty fast injector or aftermarket injection system. IMO, if you plan to go 4000 or more RPM, call Swamps.. they'll tell you what you need. They've been pushing the 7.3 RPM range quite a bit lately.
2001 V10 freeze plugs 427 fordman 1999 to 2016 Super Duty 1 12-14-2014 05:53 PM
V10 Exhaust Studs avgjoe 1999 to 2016 Super Duty 7 11-14-2014 04:41 PM
Where to buy stainless exhaust studs besides dealer? Soarer 1987 - 1996 F150 & Larger F-Series Trucks 12 02-18-2014 10:41 AM
Ex manifold studs 02 v 10 stan'37 Modular V10 (6.8l) 3 01-25-2014 02:39 PM
studs different sizes front to rear- how to correct? hasteranger 1973 - 1979 F-100 & Larger F-Series Trucks 4 10-19-2010 09:15 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
