head studs, etc. - Page 2 - Ford Truck Enthusiasts Forums
head studs, etc.
Old 10-05-2013, 04:09 PM
JSchuricht JSchuricht is offline
JSchuricht is starting off with a positive reputation.
I haven't done my 95 yet but I did do my 00 a few months ago. It sucks spending that much time on top of the engine. Invest in a top side creeper before you start. Pull the rockers and injectors first so you have less stuff to fight.
The ARP studs I used said to just put them in hand tight but due to being able to clean the holes I had to use a 1/4 drive ratchet to bottom out the studs. That's really important for the short studs that go under the injector hold down brackets. The brackets did rub the studs during installation I gave mine a slight tap to get them into place, others have ground the bracket for clearance.
Get new seals for the valve stems, you will have to pull the old ones to get the micrometer on anyways. I used a long #1 phillips screwdriver into the injector tip hole to find TDC. You will need to keep a hand on the screw driver while rotating the engine so it doesn't bind. Get the Ford tool for compressing valve springs if you can find it. Makes reaching all the springs easy.
Old 10-05-2013, 05:19 PM
427 fordman's Avatar
427 fordman 427 fordman is offline
427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.
I hope mine go as good as Ronnie's did. Thanks again guys.
That tool pictured above is available on ebay for 130ish. I'm still pretty sure I can get by with what I have or make something work.
Old 10-05-2013, 06:27 PM
stainlessstroker95's Avatar
stainlessstroker95 stainlessstroker95 is offline
stainlessstroker95 has a good reputation on FTE.stainlessstroker95 has a good reputation on FTE.stainlessstroker95 has a good reputation on FTE.
I didnt know ford actuly made a tool for springs.
Old 10-06-2013, 12:11 PM
Awitte58's Avatar
Awitte58 Awitte58 is offline
Awitte58 has a good reputation on FTE.Awitte58 has a good reputation on FTE.Awitte58 has a good reputation on FTE.
For $130 id rather ask that member to borrow his! lol
Who was that Gabe? I can picture his face (and his wives)when we were stuffing barbecue down our gullets, but still the name escapes me...
Old 10-06-2013, 12:27 PM
oldbird1965's Avatar
oldbird1965 oldbird1965 is offline
oldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to behold
His name is Roland, a really, really nice guy. Why pay a $130 for something you'll use once. Unless you actually remove the motor mounts I don't see how you would get them without that tool. Maybe you plan on pulling the motor, IDK.
Yeah Gabe, Ford makes that tool, only $450. Roland made his by copying it.
Old 10-06-2013, 12:40 PM
rodneywar's Avatar
rodneywar rodneywar is offline
rodneywar has a good reputation on FTE.rodneywar has a good reputation on FTE.
you dont have to remove motor to do springs i just went to autozone and got the valve spring compressor tool and modified it to work got all of em easily. hardest part was miccing each one
Old 10-06-2013, 12:55 PM
I didn't remove my motor either, I was just saying............Darin is a great mechanic, he will get the job done without breaking a sweat.
Old 10-06-2013, 01:06 PM
fordpride's Avatar
fordpride fordpride is offline
fordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant future
That tool isn't worth 130
It looks easy to make
I think i could make that with stuff around the shop in a couple hours
Old 10-06-2013, 03:10 PM
cowmilker08's Avatar
cowmilker08 cowmilker08 is offline
cowmilker08 has a very good reputation on FTE.cowmilker08 has a very good reputation on FTE.cowmilker08 has a very good reputation on FTE.
Most people don't have a couple of hours to spend building a tool. I've built 2 special tools to work on these engines if anyone wants to borrow them. I made an ipr wrench and a wrench to get the lower driver's side turbine inlet flange nut.
Old 10-07-2013, 09:12 AM
DIYMechanic's Avatar
DIYMechanic DIYMechanic is offline
DIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to behold
Subscribing. Darin, if you need valve stem seals let me know. I think I have a set of them in a bunch of PSD stuff I bought from a guy. They're yours for the ride if you want them. I think there is a full set still in the bag.
Old 10-07-2013, 12:17 PM
So how expensive is it to do springs, studs, and push rods?
Old 10-07-2013, 02:36 PM
I got my kit from Irate Diesel for $900.
  #28
Old 10-07-2013, 05:04 PM
Thanks Nate, I appreciate it, but I have some ordered so I should be good. Over the last 3 days I got so much more crap piled on me I have no idea when I will get this done. Some paying crap, some not. These things gotta be done before the snow falls too. The truck doesn't.
  #29
Old 10-08-2013, 10:16 AM
Awitte58's Avatar
IIRC on Riffraff you can get the studs for about $570 and the springs for $85 and the shims are like $7. I think the pushrods on Riffraff are about $220.
So all that wrapped up in a box with yellow tape and tax to your door.. Close to $1000?
You could probably find options to knock a bit off at diff sites. Im just quoting Riffraff prices. The money you'd save doing individually at other places probably would be lost in shipping individually. lol
  #30
Old 10-11-2013, 12:04 PM
All of my nice new parts are here. It's probably gonna be a month or so before I can get to putting them in, but they're here anyway.
Also, I stopped at Napa yesterday and they are getting me some shaeffers oil. They have it at another store, so it will be there today. I'm going in to pick up my granddaughter in a few hours so I'll grab it then.
2001 V10 freeze plugs 427 fordman 1999 to 2016 Super Duty 1 12-14-2014 04:53 PM
V10 Exhaust Studs avgjoe 1999 to 2016 Super Duty 7 11-14-2014 03:41 PM
Where to buy stainless exhaust studs besides dealer? Soarer 1987 - 1996 F150 & Larger F-Series Trucks 12 02-18-2014 09:41 AM
Ex manifold studs 02 v 10 stan'37 Modular V10 (6.8l) 3 01-25-2014 01:39 PM
studs different sizes front to rear- how to correct? hasteranger 1973 - 1979 F-100 & Larger F-Series Trucks 4 10-19-2010 08:15 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
