4x4 won't engage without hubs locked
Old 10-04-2013, 12:30 PM
davbeisner's Avatar
davbeisner
davbeisner is offline
As the title says, on my '03 F-350 my 4x4 won't engage without the hubs locked. My shop told me it was the 4x4 vacuum switch and replaced it, but still isn't working. They also just replaced the front drive shaft which had worn out knuckles that were "grinding." Thoughts on the next step?
Old 10-04-2013, 12:48 PM
psvienneau's Avatar
psvienneau
psvienneau is offline
sounds like one of your vacuum lines is leaking,Maybe fell off or a break in the line.I took mine out completely and went with Warn locking hubs and don't have this problem any more, when I want 4X4 I just lock um in and presto I have 4X4.
Old 10-04-2013, 02:03 PM
lupuseven's Avatar
lupuseven
lupuseven is offline
YouTube Certified Mech
Did you replace the O-rings on the hubs when you replaced drive shaft?
Welcome to guzzle's 4x4 Autolock Hub Lubrication Maintenance Web Page
from what Ive read that seems to be the main culprit for it not working, asuming you/they checked all the vacuum lines like psvienneau had said
Enduroman
1999 to 2016 Super Duty
07-25-2019 06:28 PM
xpl0sive
10-26-2012 09:43 PM
parkland
6.4L Power Stroke Diesel
01-29-2012 08:59 PM
rayashworth
45
12-08-2008 06:28 PM
sitzerland
1983 - 2012 Ranger & B-Series
12-08-2007 07:00 AM
Quick Reply: 4x4 won't engage without hubs locked
