VALUE OF A FLAT HEAD V8 - Ford Truck Enthusiasts Forums
Old 10-04-2013, 09:15 AM
Brettzky Brettzky is offline
Brettzky is starting off with a positive reputation.
Hey guys so I have never worked on or done anything with a flat head V8 so I have two quesiton for you
1) Ball park what does it cost to rebuild a flat head out of a 52 Mercury M-1?
2) What is the vlaue of a dead flat head with EVERYTHING on it manifolds, carb, EVERYTHING LONG BLOCK?
Thanks for the help
Brett
Old 10-04-2013, 10:10 PM
81silas47 81silas47 is offline
81silas47 is starting off with a positive reputation.
i can tel you this much ... get yourself a ball park figure and double it n youll hopefully have things about covered... i just ordered an engine kit for my 47 pickup today... that cost about 2400 bucks.. im guessing ill have at least 500 in machining.. and ill be spending ply another 1000 at least on odds n ends like headers, carb kit, ignition system, water pump rebuild kits and the list goes on.. those #s come to about 4 grand and i was thinking at least 5 so wel see how it turns out... im sure there will be more.. good luck
silas
Old 10-04-2013, 10:29 PM
I may just sell the motor as is if that's the case cause I have a 347 all ready to go
What you think the motor is worth as is?
Old 10-05-2013, 02:29 PM
man idk.. is it seized ? i bought 2 47 half tons together with some very minor tune ups n fiddling around i managed to get them both to run... so the engines themselves were in decent shape for what they are... i payed 2500 bucks for the 2 pickups... i guess it depends where your from and who wants them bad enough.. tose old flatheads are getting more and more rare.. if its seized and needs a major overhaul i dont think id pay more than a few hundred but you might find a hardcore flatheader that will pay through his nose
Old 10-27-2013, 11:11 AM
oldmerc's Avatar
oldmerc oldmerc is offline
oldmerc
oldmerc is a name known to alloldmerc is a name known to alloldmerc is a name known to alloldmerc is a name known to alloldmerc is a name known to alloldmerc is a name known to all
OK Ball park . To clean ,magnaflux , bore , maybe pin a couple of small cracks in the deck , install a couple of sleeves , bore for oversize pistons , grind and polish the crank , install cam bearings , rebush and hone the rods . Then you need parts gasket set , pistons and rings . main and rod bearings , oil pump , 2 water pumps , grind flywheel replace clutch assembly , fuel pump , rebuild carb , rebuild or replace distributor . $5000.00 depending on how much of this you can do yourself . Also I probably forgot a few things .
Flat heads and headers. michael a 1947 and Older Ford Trucks 8 01-13-2016 09:07 PM
flat head artscott61 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 10-22-2015 11:59 AM
My truck finally told me what it wanted Skalywag 1948 - 1956 F1, F100 & Larger F-Series Trucks 18 08-18-2015 09:26 PM
Belts classicrat52 1948 - 1956 F1, F100 & Larger F-Series Trucks 0 05-08-2015 08:30 AM
Ford flat head pros and cons Pappys53 1948 - 1956 F1, F100 & Larger F-Series Trucks 4 04-25-2014 05:16 PM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
