81 429 Ignition issues - Ford Truck Enthusiasts Forums
Old 10-03-2013, 08:59 PM
Garmo Garmo is offline
Garmo is starting off with a positive reputation.
Hey guys,
I have a 1981 Ford C700 with a 7.0 429. Just stopped running and I know it is spark related. I have done a lot of research online the last few days and am still confused. I simply cannot find an ignition control module anywhere. Is this possible for the motor to not have one? It is a duraspark distributor. I am getting voltage to the coil, but no spark. I can't find the ICM to test it and now think it is the coil pick up in the dist.
Can anyone confirm if this motor can run with the duraspark dist and no ICM?
NAPA did not have a listing for one, but OReilly does.
Any help is appreciated with troubleshooting this problem.
Thanks,
Gary
Old 10-04-2013, 11:29 AM
Gus Erickson's Avatar
Gus Erickson Gus Erickson is offline
Gus Erickson is starting off with a positive reputation.
My 1986 F250 with a 460 was a wiring mess when I got it. I switched to an HEI distributor. 1 wire to fire it and 1 wire to your tach. Very simple. I got mine on Ebay from Skip White. 39 bucks. Its very simple to hook up. I may get beat up for suggesting this. But, this is the 3rd swap we have done. All with success.
Old 10-04-2013, 12:22 PM
Gus,
Thanks for sharing that. I like simple. This is my first Ford and am not quite sure as to the interchangability of parts from year to year. I assume any HEI for a big block ford will work right? What did you do with your ICM? Just pull it out and cap the wires?
Duraspark II wiring help. Tkelly44 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 23 09-04-2015 02:57 PM
Been through Everything!?,weak spark, no start, duraspark ign. Please Help! 1979F150..429 1973 - 1979 F-100 & Larger F-Series Trucks 40 08-06-2015 05:43 PM
tfi(square) coil with duraspark ignition seanthefordguy 1987 - 1996 F150 & Larger F-Series Trucks 0 04-20-2015 05:46 PM
351 Windsor Starting/Firing Issues Benefiel 1987 - 1996 F150 & Larger F-Series Trucks 4 05-15-2014 09:52 AM
94 F 250 no spark,coil, icm, no luck ajacks 1987 - 1996 F150 & Larger F-Series Trucks 10 07-12-2003 02:45 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
