9 Inch Rear, Not so easy.
Received 4,132 Likes
on
Some 9's have an 8.7" ring gear, but everything else is the same.
9 inch ~ Mid-year 1969: FoMoCo changed the differential bearings (4221) & cups (4222) to a "Slim Line" design, then used 'em thru 1986 (see pic in post 11).
Since all the bearings & cups have BIN's stamped on them, buying from autoparts stores is EZ as these are the Bearing Industry Numbers also used by bearing shops.
Some 1974/79 9's have a ball type axle bearing, some have a tapered roller bearing/seal combination.
The ONLY way to find out which is which, is by pulling an axle and taking a look-see.
Sorry, I am computer challenged. Just did a google image search and found this:
https://www.google.com/search?q=ford...tm%3B380%3B363
The two middle pics in the top row show the curved rib.
bulletsneverlie
05-29-2010 04:22 PM
49willard
03-08-2006 03:14 PM
